Commit de38ef42 authored by POTTIER Francois's avatar POTTIER Francois
Export general.ml.html.
parent e7387a83
...@@ -154,7 +154,7 @@ check: ...@@ -154,7 +154,7 @@ check:
RSYNC := scp -p -C RSYNC := scp -p -C
TARGET := yquem.inria.fr:public_html/menhir/ TARGET := yquem.inria.fr:public_html/menhir/
PAGE := /home/fpottier/dev/page PAGE := /home/fpottier/dev/page
API := convert.mli.html IncrementalEngine.ml.html API := convert.mli.html IncrementalEngine.ml.html general.mli.html
export: export:
# Copier l'archive et la doc vers yquem. # Copier l'archive et la doc vers yquem.
...@@ -54,7 +54,7 @@ ...@@ -54,7 +54,7 @@
\newcommand{\menhirlibconvert}{\href{http://gallium.inria.fr/~fpottier/menhir/convert.mli.html}{\texttt{MenhirLib.Convert}}\xspace} \newcommand{\menhirlibconvert}{\href{http://gallium.inria.fr/~fpottier/menhir/convert.mli.html}{\texttt{MenhirLib.Convert}}\xspace}
\newcommand{\menhirinterpreter}{\texttt{MenhirInterpreter}\xspace} \newcommand{\menhirinterpreter}{\texttt{MenhirInterpreter}\xspace}
\newcommand{\menhirlibincrementalengine}{\href{http://gallium.inria.fr/~fpottier/menhir/IncrementalEngine.ml.html}{\texttt{MenhirLib.IncrementalEngine}}\xspace} \newcommand{\menhirlibincrementalengine}{\href{http://gallium.inria.fr/~fpottier/menhir/IncrementalEngine.ml.html}{\texttt{MenhirLib.IncrementalEngine}}\xspace}
\newcommand{\menhirlibgeneral}{\href{http://gallium.inria.fr/~fpottier/menhir/General.ml.html}{\texttt{MenhirLib.General}}\xspace} \newcommand{\menhirlibgeneral}{\href{http://gallium.inria.fr/~fpottier/menhir/general.mli.html}{\texttt{MenhirLib.General}}\xspace}
\newcommand{\cmenhir}{\texttt{menhir}\xspace} \newcommand{\cmenhir}{\texttt{menhir}\xspace}
\newcommand{\ml}{\texttt{.ml}\xspace} \newcommand{\ml}{\texttt{.ml}\xspace}
\newcommand{\mli}{\texttt{.mli}\xspace} \newcommand{\mli}{\texttt{.mli}\xspace}
...@@ -2096,7 +2096,7 @@ tools for this purpose. ...@@ -2096,7 +2096,7 @@ tools for this purpose.
A parser stack can be viewed as a stream of elements, where the first element A parser stack can be viewed as a stream of elements, where the first element
of the stream is the topmost element of the stack. (The type \verb+'a stream+ of the stream is the topmost element of the stack. (The type \verb+'a stream+
is defined in the module \menhirlibgeneral.) % TEMPORARY export this HTML file is defined in the module \menhirlibgeneral.)
This stream is empty if the parser is in an initial state, and non-empty otherwise. This stream is empty if the parser is in an initial state, and non-empty otherwise.
% (Which initial state? -- no way to know...) % (Which initial state? -- no way to know...)
In the latter case, In the latter case,
...@@ -15,7 +15,7 @@ installation.ml: ...@@ -15,7 +15,7 @@ installation.ml:
# Pretty-printing the MenhirLib.Convert API. # Pretty-printing the MenhirLib.Convert API.
api: convert.mli.html IncrementalEngine.ml.html api: convert.mli.html IncrementalEngine.ml.html general.mli.html
%.mli.html: %.mli %.mli.html: %.mli
caml2html -nf $< caml2html -nf $<
