Commit 9f327f08 authored by POTTIER Francois's avatar POTTIER Francois
Avoid using $(shell pwd) in Makefile, for better Windows compatibility.
parent 8830bf80
2015/10/12:
2015/10/05: 2015/10/05:
Fixed a bug where inconsistent OCaml code was generated when --table Fixed a bug where inconsistent OCaml code was generated when --table
and --external-tokens were used together. (Reported by Darin Morrison.) and --external-tokens were used together. (Reported by Darin Morrison.)
...@@ -61,7 +61,11 @@ stage1: ...@@ -61,7 +61,11 @@ stage1:
# Do not use . to refer to the current directory, because ocamlbuild # Do not use . to refer to the current directory, because ocamlbuild
# descends into another directory when executing commands. # descends into another directory when executing commands.
SRC := $(shell pwd) # Do not use $(shell pwd) either, because this assumes we are running
# on a Unix platform, and can fail on Windows.
# So, use .., which works fine if ocamlbuild has effectively descended
# into a subdirectory.
SRC := ..
FLAGS := -v -lg 1 -la 1 -lc 1 --comment --infer --stdlib $(SRC) --strict --fixed-exception FLAGS := -v -lg 1 -la 1 -lc 1 --comment --infer --stdlib $(SRC) --strict --fixed-exception
