Commit 599d30cd authored by POTTIER Francois's avatar POTTIER Francois
More stuff in Printers.
parent bb5a11f1
module Make module Make
(I : MenhirLib.IncrementalEngine.INSPECTION) (E : MenhirLib.IncrementalEngine.INCREMENTAL_ENGINE)
with type 'a lr1state = 'a E.lr1state)
(User : sig (User : sig
val arrow: string (* should include space on both sides *) val arrow: string (* should include space on both sides *)
val dot: string val dot: string
...@@ -10,9 +12,19 @@ module Make ...@@ -10,9 +12,19 @@ module Make
open User open User
(* Buffer and string utilities. *)
let out = let out =
Buffer.add_string Buffer.add_string
let with_buffer f x =
let b = Buffer.create 128 in
f b x;
Buffer.contents b
let into_buffer f b x =
out b (f x)
(* Printing a list of symbols. An optional dot is printed at offset (* Printing a list of symbols. An optional dot is printed at offset
[i] into the list [symbols], if this offset lies between [0] and [i] into the list [symbols], if this offset lies between [0] and
the length of the list (included). *) the length of the list (included). *)
...@@ -45,16 +57,49 @@ module Make ...@@ -45,16 +57,49 @@ module Make
let buffer_production b prod = let buffer_production b prod =
buffer_item b (prod, -1) buffer_item b (prod, -1)
f b x;
Buffer.contents b
let print_item = let print_item =
with_buffer buffer_item with_buffer buffer_item
let print_production = let print_production =
with_buffer buffer_production with_buffer buffer_production
(* Printing an element as a symbol. *)
let print_element_as_symbol element =
match element with
| E.Element (s, _, _, _) ->
print_symbol (I.X (I.incoming_symbol s))
let buffer_element_as_symbol =
into_buffer print_element_as_symbol
(* Folding over a stream. *)
let rec foldr f xs accu =
match Lazy.force xs with
| E.Nil ->
accu
| E.Cons (x, xs) ->
f x (foldr f xs accu)
(* Printing a stack or an environment. These functions are parameterized
over an element printer. [print_element_as_symbol] can be used for
this purpose; but the user can define other printers if desired. *)
let buffer_stack buffer_element b stack =
foldr (fun element () ->
buffer_element b element;
out b space
) stack ()
let buffer_env buffer_element b env =
buffer_stack buffer_element b (E.view env)
let print_stack print_element stack =
with_buffer (buffer_stack (into_buffer print_element)) stack
let print_env print_element env =
with_buffer (buffer_env (into_buffer print_element)) env
end end
...@@ -8,6 +10,18 @@ module Make ...@@ -8,6 +10,18 @@ module Make
end) end)
: sig : sig
(* Printing an element as a symbol. This prints just the symbol
that this element represents; nothing more. *)
val buffer_element_as_symbol: Buffer.t -> E.element -> unit
val print_element_as_symbol: E.element -> string
val buffer_stack: (Buffer.t -> E.element -> unit) -> Buffer.t -> E.element E.stream -> unit
(* Printing an item. *) (* Printing an item. *)
val buffer_item: Buffer.t -> I.item -> unit val buffer_item: Buffer.t -> I.item -> unit
