Commit 579d3202 authored by POTTIER Francois's avatar POTTIER Francois
Save a tiny bit of time by using unsafe array accesses in [InfiniteArray].
These accesses are really safe, the bounds check is performed by [ensure].
parent 30c64a88
...@@ -23,6 +23,7 @@ let rec new_length length i = ...@@ -23,6 +23,7 @@ let rec new_length length i =
new_length (2 * length) i new_length (2 * length) i
let ensure a i = let ensure a i =
assert (0 <= i);
let table = a.table in let table = a.table in
let length = Array.length table in let length = Array.length table in
if i >= length then begin if i >= length then begin
...@@ -33,17 +34,17 @@ let ensure a i = ...@@ -33,17 +34,17 @@ let ensure a i =
let get a i = let get a i =
ensure a i; ensure a i;
a.table.(i) Array.unsafe_get a.table (i)
let set a i x = let set a i x =
a.table.(i) <- x; Array.unsafe_set a.table (i) x;
a.extent <- max (i + 1) a.extent a.extent <- max (i + 1) a.extent
let update a i f = let update a i f =
let x = a.table.(i) in let x = a.table.(i) in
a.table.(i) <- f x; Array.unsafe_set a.table (i) (f x);
let extent a = let extent a =
