GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
POTTIER Francois
menhir
ff33b05d
ff33b05d
POTTIER Francois
Cleanup and nicer output in bench/good/Makefile.
e4d72f52
2
bench/good/.gitignore
ff33b05d
*.ml
*.ml
*.mli
*.mli
*.result
*.result
*.out
*.automaton
*.automaton
*.conflicts
*.conflicts
failures
failures
bench/good/Makefile
ff33b05d
@@ -14,8 +14,8 @@ CAMLC := $(shell if ocamlfind ocamlc -v >/dev/null 2>&1 ; \
then
echo
ocamlc.opt
then
echo
ocamlc.opt
else
echo
ocamlc
fi
else
echo
ocamlc
fi
La convention de nommage des tests multi-grammaires
Some tests involve several input files. The naming convention for
est : /nom
/-[1-9].mly
these tests is /name
/-[1-9].mly
TESTS
shell
ls
| egrep
'*([1]|[^2-9]
.mly'
TESTS
shell
ls
| egrep
'*([1]|[^2-9]
.mly'
RESULTS
$(TESTS:.mly=.result)
RESULTS
@@ -24,42 +24,49 @@ test: clean $(RESULTS)
echo
WARNINGS:
echo
WARNINGS:
cat
warnings
cat
warnings
fi
fi
if
test
-e
failures
then
if
test
-e
failures
then
echo
FAILURES:
echo
FAILURES:
cat
failures
cat
failures
exit
exit
fi
fi
# The file %.result stores the output of menhir --only-preprocess.
# The file %.expected stores its expected output.
# The file %.out stores the output of menhir.
# (There is presently no expected output file.)
%.result
%.mly
%.result
%.mly
# Single-file or multi-file test?
if
echo
grep
-e
"-1.mly"
/dev/null;
then
if
echo
grep
-e
"-1.mly"
/dev/null;
then
export
BASE
echo
sed
s/
"-1.mly"
export
BASE
echo
sed
s/
"-1.mly"
export
FILES
echo
BASE-[1-9].mly
export
FILES
echo
BASE-[1-9].mly
export
CMD
FILES --base
BASE"
export
CMD
FILES --base
BASE"
else
else
export
FILES
export
FILES
export
BASE
echo
sed
s/
".mly"
export
BASE
echo
sed
s/
".mly"
export
CMD
export
CMD
fi
fi
$(SHELL)
-c
$(MENHIR)
--only-preprocess $$CMD >& $@'
$(SHELL)
-c
$(MENHIR)
if
x
CREATE_EXPECTED
x
"1"
then
if
x
CREATE_EXPECTED
x
"1"
then
cp
.expected
cp
.expected
fi
fi
if
test
-e
.expected
then
if
test
-e
.expected
then
if
diff
.expected
& /dev/null
then
if
diff
.expected
& /dev/null
then
if
$(MENHIR)
CMD
& /dev/null
then
if
$(MENHIR)
CMD
.out
then
echo
"[OK]
FILES"
echo
"[OK]
FILES"
else
else
echo
"-> [KO]
FILES:"
tee
-a
failures
echo
"-> [KO]
FILES:"
echo
" menhir --only-preprocess succeeded,"
tee
-a
failures
echo
echo
" but menhir failed."
tee
-a
failures
echo
fi
echo
" cat
.out"
else
tee
-a
failures
echo
"-> [KO]
FILES:"
tee
-a
failures
fi
echo
" menhir --only-preprocess produced unexpected output."
else
fi
echo
"-> [KO]
FILES:"
echo
" menhir --only-preprocess produced wrong output."
echo
" diff
.expected
tee
-a
failures
fi
else
else
echo
"Warning: missing file:
.expected"
tee
-a
warnings
echo
.expected"
tee
-a
warnings
fi
fi
Supports
