Commit f4390675 authored by POTTIER Francois's avatar POTTIER Francois
Removed my recent big comment on --depend, which was mostly wrong.
parent 4b46e509
* understand whether/why --depend needs a mock [.mli] file too
* Confirm and understand why the code back-end slows down by 50%
between 4.01.0 and 4.02.1. Use the tag last309 for this purpose,
or the master branch.
......@@ -80,8 +80,8 @@ let () =
(* If [--depend] was specified on the command line, perform dependency
analysis and stop. *)
(* If [--depend] or [--raw-depend] was specified on the command line,
perform dependency analysis and stop. *)
let () =
match Settings.depend with
......@@ -91,37 +91,12 @@ let () =
| Settings.OMNone ->
(* [--depend] is really a strange hack: we are expected to be able to predict
the dependencies exhibited by the [.ml] and [.mli] files produced by
Menhir, *without* actually producing these files, because we cannot yet
produce them. (If [--infer] is enabled, producing these files would require
consulting certain [.cmi] files that may not exist yet.) *)
(* Remarks. 1- If [make] was not brain-dead, we would not have to do this in
the first place. A good compilation manager should be able to mix the
production of targets and the dependency analysis. Apparently, by this
definition, [ocamlbuild] is brain-dead too: it uses [menhir --raw-depend].
2- We are able to do this because we can produce mock [.ml] and [.mli]
files that exhibit the same dependencies as the real ones. This allows us
to run [ocamldep] on these mock files and obtain correct depdendency
information. Traditionally, our mock [.mli] file was in fact the final
[.mli] file, and our mock [.ml] file contained just the semantic actions
and nothing else. (But see 4- below.)
3- If both [--depend] and [--infer] are enabled, we must effectively ignore
[--infer] and perform the dependency computation without attempting to
perform type inference. Indeed, as mentioned above, that would require
4- As of 2014/12/17, we would like to produce as part of the [.mli] file
a type [nonterminal] which lists all nonterminal symbols together with
their OCaml type. This typically requires [--infer]. Thus, this implies
that the mock [.mli] file can no longer be the same as the final [.mli]
file; the mock cannot contain the type [nonterminal]. As a result, maybe
the dependencies (computed based on the mock) will be incomplete. Which
would be a problem (failure to build). I am not sure at the moment how
to address this problem. *)
(* The purpose of [--depend] and [--raw-depend] is to support [--infer].
Indeed, [--infer] is implemented by producing a mock [.ml] file (which
contains just the semantic actions) and invoking [ocamlc]. This requires
certain [.cmi] files to exist. So, [--depend] is a way for us to announce
which [.cmi] files we need. It is implemented by producing the mock [.ml]
file and running [ocamldep] on it. *)
......@@ -242,11 +242,10 @@ let depend grammar =
print_string output;
(* If [--raw-depend] was specified on the command line, stop here.
This option is used by omake, which performs its own
postprocessing of [ocamldep]'s output. For normal [make] users,
who use [--depend], some postprocessing is required, which is
performed below. *)
(* If [--raw-depend] was specified on the command line, stop here. This
option is used by omake and by ocamlbuild, which performs their own
postprocessing of [ocamldep]'s output. For normal [make] users, who use
[--depend], some postprocessing is required, which is performed below. *)
begin match Settings.depend with
| Settings.OMNone ->
Supports Markdown
