Commit f27c4a36 authored by POTTIER Francois's avatar POTTIER Francois
Manual: mention sedlex instead of ulex.
parent f0599250
Pipeline #178665 failed with stage
...@@ -4600,7 +4600,7 @@ possible to convert them, after the fact, to a simpler, revised API. In the ...@@ -4600,7 +4600,7 @@ possible to convert them, after the fact, to a simpler, revised API. In the
revised API, there are no lexing buffers, and a lexer is just a function from revised API, there are no lexing buffers, and a lexer is just a function from
unit to tokens. Converters are provided by the library module unit to tokens. Converters are provided by the library module
\menhirlibconvert. This can be useful, for instance, for users of \menhirlibconvert. This can be useful, for instance, for users of
\texttt{ulex}, the Unicode lexer generator. Also, please note that \menhir's \texttt{sedlex}, the Unicode-friendly lexer generator. Also, please note that \menhir's
incremental API (\sref{sec:incremental}) does not mention the type incremental API (\sref{sec:incremental}) does not mention the type
\verb+Lexing.lexbuf+. In this API, the parser expects to be supplied with \verb+Lexing.lexbuf+. In this API, the parser expects to be supplied with
triples of a token and start/end positions of type \verb+Lexing.position+. triples of a token and start/end positions of type \verb+Lexing.position+.
