Commit f22dc891 authored by POTTIER Francois's avatar POTTIER Francois
CHANGES entry.
parent 4364e009
...@@ -4,6 +4,10 @@ ones. This circumvenents a limitation of vm_compute on 32 bit ...@@ -4,6 +4,10 @@ ones. This circumvenents a limitation of vm_compute on 32 bit
machines. This also enables us to perform sharing between machines. This also enables us to perform sharing between
definitions, so that the generated files are much smaller. definitions, so that the generated files are much smaller.
2016/04/10:
When printing a grammar (which is done by the --only-preprocess options),
remove the leading bar '|', for compatibility with yacc and bison.
2016/03/11: 2016/03/11:
In the code back-end, generate type annotations when extracting a semantic In the code back-end, generate type annotations when extracting a semantic
value out of the stack. When working with a semantic value of some function value out of the stack. When working with a semantic value of some function
Supports Markdown
