Commit edb92949 authored by POTTIER Francois's avatar POTTIER Francois
Remove the old good/Makefile and bad/Makefile.
parent 3a07b255
.PHONY: clean test expected .PHONY: test clean expected
# Note that there is potential confusion between src/_stage1/menhir # ------------------------------------------------------------------------------
# and src/_stage2/menhir. Here, we use the latter (built by "make # The test scripts are now written in OCaml.
# bootstrap" in the src/ directory). But typing "make" in the src/
# directory re-builds only the former.
SHELL=/bin/bash test expected:
SRC=../../src @ $(MAKE) -C ../src test
MENHIR=$(SRC)/_stage2/menhir.native --stdlib $(SRC)
# La convention de nommage des tests multi-grammaires clean::
# est : /nom/-[1-9].mly rm -f *~ *.ml *.mli *.conflicts *.automaton
TESTS=$(shell ls *.mly | egrep '.*([1]|[^2-9]).mly') rm -f *.result
RESULTS=$(TESTS:.mly=.result)
test: clean $(RESULTS)
@ if test -e failed_files; then \
echo FAILED ON: ; \
cat failed_files; \
fi
%.result: %.mly
# Check if there is a group of several .mly files, or just one .mly file.
@ if echo $< | grep -e "-1.mly" &> /dev/null; then \
export BASE=`echo $< | sed s/"-1.mly"/""/`; \
export FILES=`echo $$BASE-[1-9].mly`; \
export CMD="$$FILES --base $$BASE"; \
else \
export FILES="$<"; \
export CMD="$<"; \
fi; \
if $(MENHIR) $$CMD >& /dev/null; then \
echo "-> [KO] menhir should not accept $$FILES"; \
export FAILED_FILES="$$FAILED_FILES $$FILES"; \
else \
$(SHELL) -c '$(MENHIR) $$CMD >& $@'; \
if [ x$$CREATE_EXPECTED == x"1" ]; then \
cp $@ $*.expected; \
fi; \
if [ x$$VERBOSE == x"1" ]; then \
echo "********************************************************"; \
echo "* INPUT"; \
cat $<; \
echo "* OUTPUT"; \
cat $@; \
echo ""; \
fi; \
if test -e $*.expected; then \
if diff $@ $*.expected >& /dev/null; then \
echo "[OK] $$FILES"; \
else \
echo "-> [KO] menhir gives bad error message on $$FILES"; \
echo " $$FILES" >> failed_files; \
fi; \
else \
fi; \
fi
# TEMPORARY il faudrait pouvoir construire les fichiers .expected un par un
expected:
@ echo "Are you sure ? (this will erase *.expected) [Press ENTER]"
@ read
@ mkdir -p /tmp/mini-expected
@ cp -f *.expected /tmp/mini-expected >& /dev/null || true
@ CREATE_EXPECTED=1 $(MAKE) -s test
@ echo "Expected output re-generated."
# Use "make -B foo.expected" to force the reconstruction.
%.expected:
@ echo "Are you sure ? (this will erase $@) [Press ENTER]"
@ read
@ CREATE_EXPECTED=1 $(MAKE) $*.result
clean:
rm -f *.ml *.mli *.conflicts *.automaton *.cmi *.cmo *.cmx *.o *.s *.result *~ failed_files
.PHONY: clean test expected list .PHONY: test expected clean list
SHELL=/bin/bash
SRC=../../src SRC=../../src
MENHIR=$(SRC)/_stage2/menhir.native --dump --explain --stdlib $(SRC) MENHIR=$(SRC)/_stage2/menhir.native --dump --explain --stdlib $(SRC)
# Some tests involve several input files. The naming convention for # ------------------------------------------------------------------------------
# these tests is /name/-[1-9].mly. # The test scripts are now written in OCaml.
RESULTS=$(TESTS:.mly=.opp.out)
@ if test -e warnings; then \
echo WARNINGS: ; \
cat warnings; \
fi
@ if test -e failures; then \
echo FAILURES: ; \
cat failures; \
exit 1; \
fi
# The file %.flags (if it exists) stores extra flags that should be passed to Menhir.
# The file %.opp.out stores the output of menhir --only-preprocess.
# The file %.opp.exp stores its expected output.
# The file %.out stores the output of menhir.
# The file %.exp stores its expected output.
%.opp.out: %.mly
else \
export BASE=`echo $< | sed s/".mly"/""/`; \
export CMD="$<"; \
fi; \
if [ -f $*.flags ] ; then \
export CMD="$$CMD `cat $*.flags`" ; \
fi; \
$(SHELL) -c '$(MENHIR) --only-preprocess $$CMD >& $@'; \
cp $@ $*.opp.exp; \
fi; \
if test -e $*.opp.exp; then \
if diff $@ $*.opp.exp >& /dev/null; then \
if $(MENHIR) --explain $$CMD >& $*.out; then \
cp $*.out $*.exp; \
fi; \
if test -e $*.exp; then \
if ! diff $*.exp $*.out >& /dev/null; then ( \
echo "-> [KO] $$FILES:"; \
echo " menhir produced wrong output."; \
echo " diff $*.exp $*.out"; \
) | tee -a failures; \
else \
fi; \
else \
echo "Warning: missing file: $*.exp" | tee -a warnings; \
fi; \
else \
if ! grep $* 00KNOWN_FAILURES >& /dev/null; then ( \
echo " menhir --only-preprocess succeeded,"; \
echo " but menhir failed."; \
echo " more $*.out"; \
else \
echo " known failure."; \
fi; \
fi; \
else ( \
echo " menhir --only-preprocess produced wrong output."; \
echo " diff $*.opp.exp $@"; \
fi; \
else \
echo "Warning: missing file: $*.opp.exp" | tee -a warnings; \
fi; \
expected: test expected:
@ echo "Are you sure ? (this will erase *.exp) [Press ENTER]" @ $(MAKE) -C ../src test
@ read
@ mkdir -p /tmp/menhir-expected
@ cp *.exp /tmp/menhir-expected >& /dev/null || true
clean:: clean::
rm -f *~ rm -f *~ *.ml *.mli *.conflicts *.automaton
rm -f *.ml *.mli *.conflicts *.automaton rm -f *.out
rm -f *.out failures warnings
# Testing LRijkstra, that is, menhir --list-errors. # Testing LRijkstra, that is, menhir --list-errors.
