GitLab
Support
Community forum
Keyboard shortcuts
menhir
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
POTTIER Francois
menhir
dcc89cc9
dcc89cc9
POTTIER Francois
Expose the function [number] in the incremental API.
942ce961
7
7 changed files
23 additions
1 deletion
+23
-1
CHANGES
CHANGES
+1
TODO
TODO
+1
-1
doc/main.tex
doc/main.tex
+8
src/IncrementalEngine.ml
+4
src/engineTypes.ml
src/engineTypes.ml
+4
src/referenceInterpreter.ml
+3
src/tableInterpreter.ml
+2
CHANGES
dcc89cc9
@@ -4,6 +4,7 @@ A [supplier] is a function that produces tokens on demand.
[lexer_lexbuf_to_supplier] turns a lexer and a lexbuf into a supplier.
[loop] is a ready-made made main parsing loop.
[loop_handle] is a variant of [loop] that lets the user do her own error handling.
[number] maps a state of the LR(1) automaton to its number.
2015/10/16:
2015/10/16:
Incompatible change of the incremental API: renamed the type ['a result]
TODO
dcc89cc9
@@ -88,7 +88,7 @@
@@ -88,7 +88,7 @@
* Suite des patchs de Frédéric Bour.
API d'inspection complète.
Exposer le nombre d'états (pour la mémoisation)
et une conversion état -> entier
Exposer le nombre d'états (pour la mémoisation).
Idem pour les productions.
Fonctions d'affichage pour les types terminal, nonterminal, etc.?
Fonctions d'isomorphisme entre token et 'a terminal * 'a?
doc/main.tex
dcc89cc9
@@ -2149,6 +2149,14 @@ The index \verb+'a+ is the type of the semantic values associated with $A$.
The role played by
\verb
'a
is clarified in the definition of the
The role played by
\verb
'a
type
\verb
element
, which follows.
type
\verb
element
, which follows.
%% val number
\begin{verbatim}
val number:
_
lr1state -> int
\end{verbatim}
The states of the LR(1) automaton are numbered (from 0 and up).
%% type element
%% type element
\begin{verbatim}
\begin{verbatim}
dcc89cc9
@@ -113,6 +113,10 @@ module type INCREMENTAL_ENGINE = sig
type
a
lr1state
type
a
lr1state
(* The states of the LR(1) automaton are numbered (from 0 and up). *)
val
number
_
lr1state
int
(* An element is a pair of a non-initial state [s] and a semantic value [v]
associated with the incoming symbol of this state. The idea is, the value
[v] was pushed onto the stack just before the state [s] was entered. Thus,
src/engineTypes.ml
dcc89cc9
@@ -84,6 +84,10 @@ module type TABLE = sig
type
state
type
state
(* States are numbered. *)
val
number
state
int
(* The type of tokens. These can be thought of as real tokens, that is,
tokens returned by the lexer. They carry a semantic value. This type
does not include the [error] pseudo-token. *)
dcc89cc9
@@ -9,6 +9,9 @@ module T = struct
type
state
type
state
Lr1
node
Lr1
node
let
number
Lr1
number
type
token
type
token
Terminal
t
Terminal
t
dcc89cc9
@@ -5,6 +5,8 @@ module Make (T : TableFormat.TABLES)
type
state
type
state
int
int
let
number
s
s
type
token
type
token
T
token
T
token
