Une nouvelle version du portail de gestion des comptes externes sera mise en production lundi 09 août. Elle permettra d'allonger la validité d'un compte externe jusqu'à 3 ans. Pour plus de détails sur cette version consulter : https://doc-si.inria.fr/x/FCeS
Commit dc3647cb authored by POTTIER Francois's avatar POTTIER Francois Committed by POTTIER Francois
Committed Maximal and MaxHorn to the attic.
Maximal first builds the maximal automaton, then attempts to minimize it.
The first phase is made obsolete by LR1Pager (ModeInclusionOnly)
which also computes the maximal automaton, but is more efficient.
The second phase (minimization) could still be of interest in the future.
It is based on an ad hoc solver for Horn clauses.
parent 94c83072
(* Menhir *)
(* François Pottier, Inria Paris *)
(* Yann Régis-Gianas, PPS, Université Paris Diderot *)
(* Copyright Inria. All rights reserved. This file is distributed under the *)
(* terms of the GNU General Public License version 2, as described in the *)
(* file LICENSE. *)
module InfiniteArray =
MenhirLib.InfiniteArray
let postincrement =
Misc.postincrement
let unSome =
Misc.unSome
module Make () = struct
type polarity =
bool
type variable =
int
type literal =
polarity * variable
type clause =
literal list
let size clause =
match clause with
| [ _ ] ->
| _ :: _ :: _ ->
2 (* Two means two or more. *)
type solution =
variable -> polarity
(* Clauses are numbered internally. An index is a clause number. *)
type index =
int
(* The set [unresolved] contains all unresolved variables (and possibly
some resolved variables, too, which we ignore). It is set up as a
priority queue, so we can easily extract a variable of highest priority
when we so wish. *)
let unresolved : variable LowIntegerPriorityQueue.t =
LowIntegerPriorityQueue.create (-1) (* dummy *)
(* This extensible array of clauses is used to implement [declare]. *)
let clauses =
InfiniteArray.make []
(* The counter [c] is used to allocate new clauses. *)
let c : index ref =
ref 0
(* The counter [v] is used to allocate new variables. *)
let v : variable ref =
ref 0
(* This Boolean flag is used to forbid uses of [new_variable] or [declare]
after [solve] has been called. *)
let declarations_permitted =
ref true
(* A new variable is allocated as follows. *)
type priority =
int
let new_variable (p : priority) =
assert !declarations_permitted;
let x = postincrement v in
LowIntegerPriorityQueue.add unresolved x p;
x
(* We assume the property ALON: every clause has at least one negative
literal. This implies that the formulae we are looking at are always
satisfiable: they can be satisfied by setting all variables to [false].
Our goal is to set as many variables as possible to [true] while
retaining satisfiability. *)
(* In fact, we assume the property AMOP: every clause has at most one
positive literal. This property is preserved as variables are resolved,
so it is an invariant: AMOP always holds. Furthermore, in the absence
of empty clauses and unit clauses, AMOP implies ALON. (Indeed, if a
clause has at least two literals and at most one positive literal, then
it has at least one negative literal.) Thus, if unit propagation
succeeds and leaves us in a state where no unit clauses exist, then we
have ALON, hence the current formula can be satisfied by setting all
variables to [false]. *)
(* The property AMOP can also be stated as follows: every clause must be a
Horn clause. *)
(* A new clause is declared as follows. *)
let declare clause =
(* Allocate a new clause index. *)
let i = postincrement c in
(* Record this clause. *)
InfiniteArray.set clauses i clause
(* Information about the variables and clauses declared so far. *)
let stats () =
!v, !c
(* Here begins the solver. *)
module Solve () = struct
(* Declarations are no longer permitted. *)
let () =
declarations_permitted := false
(* The number of variables is now fixed. *)
let v =
!v
(* The array [resolved] maps every variable [x] to a Boolean flag that tells
whether this variable has been resolved. *)
let resolved : bool array =
Array.make v false
(* The array [value] maps every resolved variable [x] to its Boolean value. *)
let value : bool array =
Array.make v false (* dummy *)
(* The array [positive] maps an variable to the indices of the clauses
where this variable occurs positively. We do not update this array as
we make progress towards a solution, so: 1- it should be looked up at
unresolved variables only; 2- the list [positive.(x)] can contain
clauses that have become true, so [x] no longer appears in them. *)
let positive : index list array =
Array.make v []
(* The array [negative] maps a variable to the indices of the clauses where
this variable occurs negatively. *)
let negative : index list array =
Array.make v []
(* The expression [(occurrences polarity).(x)] denotes the indices of
the clauses where the literal [(polarity, x)] occurs. It is also a
left-value, i.e., it can be used on the left-hand side of an assignment. *)
let occurrences polarity =
if polarity then positive else negative
(* The array [clauses] maps a clause index to the current form of this
clause. A clause becomes simpler and simpler over time, as the
variables that appear in it are resolved. A clause can also disappear
entirely; this means that it has become satisfied. *)
(* Thus, an empty clause [Some []] means [false], whereas a missing
clause [None] means [true]. *)
(* We maintain the invariant that all of the variables that appear in a
a clause are unresolved. *)
let clauses : clause option array =
Array.map (fun clause -> Some clause) (InfiniteArray.domain clauses)
(* The bag [unit] holds the indices of the unit clauses (that is, the
clauses that have exactly one literal), in an arbitrary order.
Because a unit clause can become satisfied while it is in this bag,
we must also be prepared for this bag to contain indices of clauses
that have disappeared. *)
let unit : index Stack.t =
Stack.create()
(* Initialize [positive], [negative], and [unit]. *)
let () =
Array.iteri (fun i oclause ->
let clause = unSome oclause in
List.iter (fun (polarity, x) ->
(* Record that the literal [(polarity, x)] occurs in clause [i]. *)
let occurrences = occurrences polarity in
occurrences.(x) <- i :: occurrences.(x)
) clause;
(* If this is a unit clause, record this fact. *)
if size clause = 1 then
Stack.push i unit
) clauses
(* Support for backtracking. *)
(* In general, it is possible for unit propagation to discover that the
problem is unsatisfiable. (This can happen after we speculatively
select a variable [x] and set it to [true].) Thus, we must be prepared
to undo the changes made during unit propagation to the global arrays
[resolved] and [clauses]. For this purpose, we keep an undo trail,
represented as a closure. *)
(* Sometimes, however, we know that the problem is satisfiable and
therefore that unit propagation cannot fail. This is the case on the
very first run of unit propagation (where we have not made any
arbitrary decision yet) and on every run propagation that follows
backtracking (where we have made a wrong decision and reversed it). *)
(* For this reason, we allow [propagate] and [resolve] to run in a safe
mode where no undo information is recorded. *)
let safe_mode =
ref false
let nothing () = ()
let trail : (unit -> unit) ref =
ref nothing
let speculatively_resolve x =
assert (not resolved.(x));
resolved.(x) <- true;
if not !safe_mode then begin
let undo = !trail in
let undo () = resolved.(x) <- false; undo() in
trail := undo
let speculatively_update_clause i clause =
if !safe_mode then
clauses.(i) <- clause
else begin
let current = clauses.(i) in
clauses.(i) <- clause;
let undo () = clauses.(i) <- current; undo() in
trail := undo
(* [safely f] executes [f()] in safe mode. This means that no undo
information is recorded while [f()] is executed, and [f()] is
expected to not raise [UNSAT]. *)
exception UNSAT
let safely f =
assert (!trail == nothing);
assert (not !safe_mode);
safe_mode := true;
begin try
f()
with UNSAT ->
assert false (* should not happen *)
end;
safe_mode := false
(* Unit propagation. *)
let rec propagate () =
(* Pick a unit clause [i]. *)
if not (Stack.is_empty unit) then
let i = Stack.pop unit in
match clauses.(i) with
| None ->
(* This clause has been satisfied already. Forget about it. *)
propagate()
| Some [] ->
(* This clause has been falsified already. Impossible; we would
have aborted. *)
assert false
| Some (_ :: _ :: _) ->
(* This is not a unit clause. Impossible; we would not have put
it in the bag. *)
assert false
| Some [ (polarity, x) ] ->
(* This is a unit clause. *)
(* The variable [x] is not yet resolved. We now can and must
resolve it: its value should be [polarity]. This allows us
to simplify or satisfy the clauses where [x] occurs; in
particular, this unit clause is satisfied and disappears. *)
resolve x polarity;
(* Continue. *)
propagate()
and resolve x polarity =
speculatively_resolve x;
(* This write to the [value] array does not need to be undone. *)
value.(x) <- polarity;
(* The clauses where [x] appears must now be visited. Those where
[x] appears with polarity [polarity] become satisfied. *)
List.iter (fun i ->
if clauses.(i) <> None then (* optional test *)
speculatively_update_clause i None
) (occurrences polarity).(x);
(* Those where [x] occurs with opposite polarity can be simplified.
This may cause them to become unit clauses. This may also cause
them to become empty clauses, in which case we have detected a
contradiction. *)
List.iter (fun i ->
| None ->
| Some clause ->
(* The manner in which this is written relies on the fact that
we cannot have both [x] and [~x] in a clause. It suffices to
check for the equality [x = y], ignoring the polarity of [y]. *)
let clause = List.filter (fun (_polarity, y) -> x <> y) clause in
speculatively_update_clause i (Some clause);
match size clause with
| 0 ->
(* This clause becomes empty! Fail. *)
raise UNSAT
| 1 ->
(* This clause becomes a unit clause. *)
Stack.push i unit
| _ ->
) (occurrences (not polarity)).(x)
(* [pick()] extracts a variable with minimum priority from [unresolved].
If this variable is in fact resolved, we drop it and pick again. If it
is unresolved, we return it. If there are no more unresolved variables,
it returns [None]. *)
let rec pick () =
match LowIntegerPriorityQueue.remove unresolved with
| None ->
None
| Some x ->
if resolved.(x) then pick() else Some x
(* The main loop of the solver. *)
let picks, backtracks =
ref 0, ref 0
let rec main () =
(* At this point, we assume that the problem is currently satisfiable by
setting all variables to [false] and there are no unit clauses. (Unit
propagation has just been performed.) If all variables are resolved,
then we are done. Otherwise, we pick an unresolved variable and
attempt to set it to [true]. *)
assert (Stack.is_empty unit);
match pick() with
| None ->
| Some x ->
incr picks;
resolve x true;
(* Perform unit propagation. *)
match propagate() with
(* Unit propagation did not fail. Commit. Clear the undo trail
and continue. *)
trail := nothing;
main()
| exception UNSAT ->
(* Unit propagation failed. Revert to the state prior to unit
propagation by executing the undo trail and emptying the
bag of [unit] clauses. *)
incr backtracks;
undo();
trail := nothing;
Stack.clear unit;
(* We now know that setting [x] to [true] was a mistake. We
can therefore set it to [false] and explore the consequences
of this discovery before continuing. *)
safely (fun () -> resolve x false; propagate());
main()
(* Run the solver. *)
let () =
(* The very first run of unit propagation cannot fail, since the
problem must be satisfiable. (We have not made any arbitrary
decision.) *)
safely (fun () -> propagate());
(* Iterate the main loop. *)
main()
(* Informational output. *)
let () =
Error.logA 3 (fun f ->
(* Count how many variables have been set to [true]. *)
let c = ref 0 in
Array.iter (fun value -> if value then incr c) value;
Printf.fprintf f
"Found a solution where %d out of %d variables are set to true.\n"
!c v;
Printf.fprintf f
"%d heuristic choices of variables were made.\n"
!picks;
Printf.fprintf f
"%d backtracks were necessary.\n"
!backtracks
(* Export the solution. *)
let solution (x : variable) : polarity =
assert resolved.(x);
value.(x)
(* Re-package the functor [Solve] as a function [solve]. *)
let solve() =
let module S = Solve() in
S.solution
(* Menhir *)
(* file LICENSE. *)
(* A heuristic MaxSAT solver, tailored to the special case where the clauses
are in fact Horn clauses. *)
module Make () : sig
(* A polarity is [true] or [false]. *)
type polarity =
bool
(* A propositional variable [x] denotes an unknown Boolean value. *)
type variable
(* A literal is either a variable [x] or the negation of a variable [~x].
It can also be read as an equation [x = true] or [x = false]. *)
type literal =
polarity * variable
(* A clause is a disjunction of literals. The clauses built by the user
must satisfy the following conditions:
1. In a clause, two distinct literals must concern two distinct variables.
Thus, [x \/ x] and [~x \/ ~x], which are redundant, is forbidden,
while [x \/ ~x], which is trivially true, is forbidden as well.
2. Every clause must have at least one negative literal.
3. Every clause has at most one positive literal.
In other words, every clause is a Horn clause. *)
(* Condition 1 is basic hygiene. Condition 2 implies that the problem, a
conjunction of clauses, is satisfiable: indeed, it can be satisfied by
setting every variable to [false]. Condition 3 guarantees that condition
2 remains verified as the solver makes progress towards a solution. *)
type clause =
literal list
(* A solution is a mapping of variables to Boolean values. *)
type solution =
(* A new variable is produced by [new_variable p], where [p] is a
nonnegative integer priority. The priority [p] plays a role in
the heuristics used by the solver: a variable whose priority is
smaller runs a better chance of being assigned the value [true]. *)
type priority =
int
val new_variable: priority -> variable
(* A clause [clause] is declared to the solver by [declare clause]. *)
val declare: clause -> unit
(* [stats()] indicates how many variables and clauses have been declared.
It can be called at any time. *)
val stats: unit -> int * int
(* After [new_variable] and [declare] have been used to create all variables
and declare all clauses, the call [solve()] runs the solver and returns a
solution. (Because the problem is always satisfiable by construction, the
solver always succeeds.) The solver attempts to find a solution where as
many variables as possible are set to [true]. The solver uses a heuristic
algorithm and does not necessarily find an optimal solution. *)
val solve: unit -> solution
This diff is collapsed.
(* Menhir *)
(* file LICENSE. *)
(* This module constructs an LR(1) automaton for the grammar described by the
module [Grammar]. *)
(* In this construction, precedence declarations are not taken into account.
Thus, conflicts are not resolved; no transitions or reductions are removed
in order to resolve conflicts. As a result, every node is reachable from
some entry node. *)
open LR1Sigs
module Run () : LR1_AUTOMATON
