Commit d74341e2 authored by POTTIER Francois's avatar POTTIER Francois
Describe demos/calc-syntax-errors in the manual instead of referring the
reader to CompCert.
parent 2a668b10
......@@ -79,6 +79,7 @@
\newcommand{\repo}[2]{\href{https://gitlab.inria.fr/fpottier/menhir/blob/master/#1}{#2}}
\newcommand{\menhirlibconvert}{\repo{lib/Convert.mli}{\texttt{MenhirLib.Convert}}\xspace}
\newcommand{\menhirliberrorreports}{\repo{lib/ErrorReports.mli}{\texttt{MenhirLib.ErrorReports}}\xspace}
\newcommand{\menhirlibincrementalengine}{\repo{lib/IncrementalEngine.ml}{\texttt{MenhirLib.IncrementalEngine}}\xspace}
\newcommand{\standardmly}{\repo{src/standard.mly}{\texttt{standard.mly}}\xspace}
\newcommand{\distrib}[1]{\repo{#1}{\texttt{#1}}}
......@@ -3880,26 +3880,52 @@ declaration is complete, then at this point, a semicolon is expected''.
\subsection{A working example}
\label{sec:errors:example}
The CompCert verified compiler offers a real-world example of this approach to
error handling. The ``pre-parser'' is where syntax errors are detected: see
The demo \distrib{demos/calc-syntax-errors} illustrates this approach to error
handling. It is based on the demo \distrib{demos/calc}, which involves a very
simple grammar of arithmetic expressions. Compared with \distrib{demos/calc},
one \donerrorreduce declaration is added so as to reduce the number of error
states. There remain just 9~error states, for which we write 5~distinct syntax
error messages. These messages are stored in the file
\distrib{demos/calc-syntax-errors/parserMessages.messages}.
The file \distrib{demos/calc-syntax-errors/dune} instructs the build system to
check this file for correctness, irredundancy and completeness and to compile
this file into an OCaml module \verb+parserMessages.ml+.
This OCaml module contains a single function, \verb+ParserMessages.messages+,
which maps a state number to a diagnostic message. It is called from the main
module, \distrib{demos/calc-syntax-errors/calc.ml}.
There, we use the facilities offered by the module
\menhirliberrorreports to print a full syntax error message,
which includes the precise location of the error as well as
the diagnostic message returned by
the function \verb+ParserMessages.messages+.
As icing on the cake, we allow the diagnostic message to contain placeholders
of the form
\verb+$i+, where \verb+i+ is an integer constant, understood as a 0-based
index into the parser's stack. We replace such a placeholder with the fragment
of the source text that corresponds to this stack entry.
A number of expected-output files demonstrate the kind of syntax error
messages that we produce; see for instance
\distrib{demos/calc-syntax-errors/calc03.exp} and
\distrib{demos/calc-syntax-errors/calc07.exp}.
The CompCert verified compiler offers another real-world example. The
\compcertgithubfile{cparser/pre\_parser.mly}.
% (The pre-parser is also in charge of distinguishing type names versus variable
% names, but that is an independent issue.)
A database of erroneous input sentences and (templates for) diagnostic messages is stored in
\compcertgithubfile{cparser/handcrafted.messages}. It is compiled, using \ocompileerrors,
to an \ocaml file named \texttt{cparser/pre\_parser\_messages.ml}. The
function \verb+Pre_parser_messages.message+, which maps a state number to (a template for) a
diagnostic message, is called from
\compcertgithubfile{cparser/ErrorReports.ml},
where we construct and display a full-fledged diagnostic message.
In CompCert, we allow a template for a diagnostic message to contain the
special form \verb+$i+, where \verb+i+ is an integer constant, understood as
an index into the parser's stack. The code
in \compcertgithubfile{cparser/ErrorReports.ml} automatically replaces this
special form with the fragment of the source text that corresponds to this
stack entry. This mechanism is not built into \menhir; it is implemented in
CompCert using \menhir's incremental API.
messages is stored in \compcertgithubfile{cparser/handcrafted.messages}.
% It is compiled, using \ocompileerrors, to an \ocaml file named
% \texttt{cparser/pre\_parser\_messages.ml}. The function
% \verb+Pre_parser_messages.message+, which maps a state number to (a template
% for) a diagnostic message, is called from
% \compcertgithubfile{cparser/ErrorReports.ml}, where we construct and display a
% full-fledged diagnostic message.
