Attention une mise à jour du service Gitlab va être effectuée le mardi 14 décembre entre 13h30 et 14h00. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit d5dd4089 authored by POTTIER Francois's avatar POTTIER Francois
Document [pop_many].
parent 0f2e9c1a
......@@ -2525,6 +2525,17 @@ this stack element is the current state of the automaton. If the stack is
empty, \verb+None+ is returned. In that case, the current state of the
automaton must be an initial state.
%% val pop_many
\begin{verbatim}
val pop_many: int -> 'a env -> 'a env option
\end{verbatim}
\verb+pop_many i env+ pops \verb+i+ elements off the automaton's stack. This
is done via \verb+i+ successive invocations of \verb+pop+. Thus,
\verb+pop_many 1+ is \verb+pop+. The index \verb+i+ must be nonnegative. The
time complexity is $O(i)$.
%% val positions
\begin{verbatim}
......@@ -269,8 +269,8 @@ module type INCREMENTAL_ENGINE = sig
val top: 'a env -> element option
(* [pop_many i env] pops [i] cells off the automaton's stack. This is done by
invoking [pop] [i] times in succession. Thus, [pop_many 1] is [pop]. The
via [i] successive invocations of [pop]. Thus, [pop_many 1] is [pop]. The
index [i] must be nonnegative. The time complexity is O(i). *)
