Commit ceb43247 authored by POTTIER Francois's avatar POTTIER Francois
Detect unknown symbols in %attribute declarations.
parent b113b1b6
...@@ -641,8 +641,15 @@ let check_parameterized_grammar_is_well_defined grammar = ...@@ -641,8 +641,15 @@ let check_parameterized_grammar_is_well_defined grammar =
List.iter (check kind false) ps List.iter (check kind false) ps
in in
List.iter (check "%type" true) (List.map fst grammar.p_types); let check_fst kind must_be_nonterminal (p, _) =
List.iter (check "%on_error_reduce" true) (List.map fst grammar.p_on_error_reduce); check kind must_be_nonterminal p
in
List.iter (check_fst "%type" true) grammar.p_types;
List.iter (check_fst "%on_error_reduce" true) grammar.p_on_error_reduce;
List.iter (fun (params, _) ->
List.iter (check "%attribute" false) params
) grammar.p_symbol_attributes;
(* Every reference to a symbol is well defined. *) (* Every reference to a symbol is well defined. *)
let used_tokens = ref StringSet.empty in let used_tokens = ref StringSet.empty in
File "unknown_symbol_in_attribute.mly", line 2, characters 16-17:
Error: D is undefined.
%token A B C
%attribute list(D) [@foo "bar"] (* the symbol D is unknown, so this %attribute declaration cannot work *)
%start<unit> main
main:
A B list(C) {}
File "unused-attribute.mly", line 3, characters 19-31: File "unused-attribute.mly", line 2, characters 19-31:
Warning: this attribute could not be transferred to the symbol list(B) Warning: this attribute could not be transferred to the symbol list(B)
File "unused-attribute.mly", line 2, characters 13-25:
Warning: this attribute could not be transferred to the symbol D
Grammar has 2 nonterminal symbols, among which 1 start symbols. Grammar has 2 nonterminal symbols, among which 1 start symbols.
Grammar has 3 terminal symbols. Grammar has 3 terminal symbols.
Grammar has 3 productions. Grammar has 3 productions.
%token A B C %token A B C
%attribute D [@foo "bar"] (* the symbol D is unknown, so this %attribute declaration cannot work *)
%attribute list(B) [@foo "bar"] (* the symbol list(B) is never created during expansion, so this declaration is not OK *) %attribute list(B) [@foo "bar"] (* the symbol list(B) is never created during expansion, so this declaration is not OK *)
%attribute list(C) [@foo "bar"] (* the symbol list(C) is created during expansion, so this declaration is OK *) %attribute list(C) [@foo "bar"] (* the symbol list(C) is created during expansion, so this declaration is OK *)
%start<unit> main %start<unit> main
%start main %start main
%token A %token A
%token B %token B
