GitLab
Support
Community forum
Keyboard shortcuts
menhir
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
POTTIER Francois
menhir
ce38fc99
ce38fc99
POTTIER Francois
Comment and TODO item.
0a0f45f1
2
2 changed files
10 additions
1 deletion
+10
-1
TODO
TODO
+8
src/IncrementalEngine.ml
+2
-1
TODO
ce38fc99
* Check that the LR(0) items never have an empty left segment
(i.e. i > 0 always holds) and that their left segments are
comparable wrt to the suffix ordering.
* Define [print_result].
Define a printer that shows the states in the stack.
Try computing a set of expected symbols in the current state.
* Generate default printers for terminal and nonterminal.
* IncrementalEngine: document [lr1state], [element], [view].
ce38fc99
@@ -183,7 +183,8 @@ module type INSPECTION = sig
val
rhs
production
xsymbol
list
val
rhs
production
xsymbol
list
(* [items s] is the set of the LR(0) items in the LR(0) core of the LR(1)
state [s]. This set is presented as a list, in an arbitrary order. *)
state [s]. This set is not epsilon-closed. This set is presented as a
val
items
a
lr1state
item
list
val
items
a
lr1state
item
list
