Commit ce38fc99 authored by POTTIER Francois's avatar POTTIER Francois
Comment and TODO item.
parent 0a0f45f1
* Check that the LR(0) items never have an empty left segment
(i.e. i > 0 always holds) and that their left segments are
comparable wrt to the suffix ordering.
* Define [print_result].
Define a printer that shows the states in the stack.
Try computing a set of expected symbols in the current state.
* Generate default printers for terminal and nonterminal. * Generate default printers for terminal and nonterminal.
* IncrementalEngine: document [lr1state], [element], [view]. * IncrementalEngine: document [lr1state], [element], [view].
...@@ -183,7 +183,8 @@ module type INSPECTION = sig ...@@ -183,7 +183,8 @@ module type INSPECTION = sig
val rhs: production -> xsymbol list val rhs: production -> xsymbol list
(* [items s] is the set of the LR(0) items in the LR(0) core of the LR(1) (* [items s] is the set of the LR(0) items in the LR(0) core of the LR(1)
state [s]. This set is presented as a list, in an arbitrary order. *) state [s]. This set is not epsilon-closed. This set is presented as a
val items: 'a lr1state -> item list val items: 'a lr1state -> item list
