Commit c2584813 authored by POTTIER Francois's avatar POTTIER Francois
Remove [Positions.two].
It is replaced with [Positions.import] in a singleton list.
parent 6636a4a7
...@@ -129,7 +129,7 @@ declaration: ...@@ -129,7 +129,7 @@ declaration:
| rule_specific_token | rule_specific_token
Error.error (Positions.two $startpos $endpos) Error.error [Positions.import $loc]
"syntax error inside a declaration.\n\ "syntax error inside a declaration.\n\
Did you perhaps forget the %%%% that separates declarations and rules?" Did you perhaps forget the %%%% that separates declarations and rules?"
...@@ -75,7 +75,7 @@ module TokPrecedence = struct ...@@ -75,7 +75,7 @@ module TokPrecedence = struct
| UndefinedPrecedence -> | UndefinedPrecedence ->
| PrecedenceLevel (_, _, pos1, pos2) -> | PrecedenceLevel (_, _, pos1, pos2) ->
Error.grammar_warning (Positions.two pos1 pos2) Error.grammar_warning [Positions.import (pos1, pos2)]
"the precedence level assigned to %s is never useful." id "the precedence level assigned to %s is never useful." id
) grammar.tokens ) grammar.tokens
...@@ -26,7 +26,7 @@ let error1 pos = ...@@ -26,7 +26,7 @@ let error1 pos =
Error.error (Positions.one pos) Error.error (Positions.one pos)
let error2 lexbuf = let error2 lexbuf =
Error.error (Positions.two lexbuf.lex_start_p lexbuf.lex_curr_p) Error.error (Positions.lexbuf lexbuf)
...@@ -140,9 +140,6 @@ type positions = ...@@ -140,9 +140,6 @@ type positions =
let one (pos : position) : positions = let one (pos : position) : positions =
[ import (pos, pos) ] [ import (pos, pos) ]
let two (pos1 : position) (pos2 : position) : positions =
[ import (pos1, pos2) ]
let lexbuf (lexbuf : lexbuf) : positions = let lexbuf (lexbuf : lexbuf) : positions =
[ import (lexbuf.lex_start_p, lexbuf.lex_curr_p) ] [ import (lexbuf.lex_start_p, lexbuf.lex_curr_p) ]
...@@ -123,8 +123,6 @@ type positions = ...@@ -123,8 +123,6 @@ type positions =
val one: Lexing.position -> positions val one: Lexing.position -> positions
val two: Lexing.position -> Lexing.position -> positions
val lexbuf: Lexing.lexbuf -> positions val lexbuf: Lexing.lexbuf -> positions
(* Low-level printing function, for debugging. *) (* Low-level printing function, for debugging. *)
...@@ -23,7 +23,7 @@ ...@@ -23,7 +23,7 @@
(* A short-hand. *) (* A short-hand. *)
...@@ -84,4 +84,3 @@ rule lex = parse ...@@ -84,4 +84,3 @@ rule lex = parse
{ COLON } { COLON }
| _ | _
{ error2 lexbuf "unexpected character." } { error2 lexbuf "unexpected character." }
...@@ -66,7 +66,7 @@ ...@@ -66,7 +66,7 @@
| None, [] -> | None, [] ->
Lexing.dummy_pos (* cannot happen *) Lexing.dummy_pos (* cannot happen *)
in in
Positions.two opening closing, [Positions.import (opening, closing)],
strip_sentence (nto, terminals) strip_sentence (nto, terminals)
...@@ -118,4 +118,3 @@ terminals: ...@@ -118,4 +118,3 @@ terminals:
| TERMINAL terminals | TERMINAL terminals
{ $1 :: $2 } { $1 :: $2 }
