Commit b7e5116a authored by POTTIER Francois's avatar POTTIER Francois
Printer improvements.
The closing delimiter in records and arrays is now correctly indented.
parent 3f0f8bf4
...@@ -78,8 +78,11 @@ let space f = ...@@ -78,8 +78,11 @@ let space f =
let comma f = let comma f =
output_string f ", " output_string f ", "
let semi f =
output_char f ';'
let seminl f = let seminl f =
output_char f ';'; semi f;
nl f nl f
let times f = let times f =
...@@ -378,9 +381,9 @@ and exprk k f e = ...@@ -378,9 +381,9 @@ and exprk k f e =
| ERecordAccess (e, field) -> | ERecordAccess (e, field) ->
fprintf f "%a.%s" atom e field fprintf f "%a.%s" atom e field
| ERecord fs -> | ERecord fs ->
fprintf f "{%a}" (indent 2 (list field nothing)) fs fprintf f "{%a%t}" (indent 2 (seplist field nl)) fs nl
| EArray fs -> | EArray fs ->
fprintf f "[|%a|]" (indent 2 (list array_field nothing)) fs fprintf f "[|%a%t|]" (indent 2 (seplist array_field nl)) fs nl
| EArrayAccess (e, i) -> | EArrayAccess (e, i) ->
fprintf f "%a.(%a)" atom e expr i fprintf f "%a.(%a)" atom e expr i
else else
...@@ -411,19 +414,13 @@ and branch k f br = ...@@ -411,19 +414,13 @@ and branch k f br =
fprintf f "%a ->%a" pat br.branchpat (indent 4 (exprk k)) br.branchbody fprintf f "%a ->%a" pat br.branchpat (indent 4 (exprk k)) br.branchbody
and field f (label, e) = and field f (label, e) =
fprintf f "%s = %a%t" label app e seminl fprintf f "%s = %a%t" label app e semi
and fpats f fps =
list fpat nothing f fps
and fpat f = function and fpat f (label, p) =
| (_, PWildcard) -> fprintf f "%s = %a%t" label pat p semi
() (* in a record pattern, fields can be omitted *)
| (label, p) ->
fprintf f "%s = %a%t" label pat p seminl
and array_field f e = and array_field f e =
fprintf f "%a%t" app e seminl fprintf f "%a%t" app e semi
and pat0 f = function and pat0 f = function
| PUnit -> | PUnit ->
...@@ -443,7 +440,9 @@ and pat0 f = function ...@@ -443,7 +440,9 @@ and pat0 f = function
| PAnnot (p, t) -> | PAnnot (p, t) ->
fprintf f "(%a : %a)" pat p typ t fprintf f "(%a : %a)" pat p typ t
| PRecord fps -> | PRecord fps ->
fprintf f "{%a}" (indent 2 fpats) fps (* In a record pattern, fields can be omitted. *)
let fps = List.filter (function (_, PWildcard) -> false | _ -> true) fps in
fprintf f "{%a%t}" (indent 2 (seplist fpat nl)) fps nl
| p -> | p ->
fprintf f "(%a)" pat p fprintf f "(%a)" pat p
