Commit b134fc73 authored by POTTIER Francois's avatar POTTIER Francois
Remove a TODO item.
parent fe60419c
Pipeline #120126 passed with stages
in 25 seconds
...@@ -20,10 +20,6 @@ ...@@ -20,10 +20,6 @@
* OCaml warnings about unused variables can be reported in the mock file. * OCaml warnings about unused variables can be reported in the mock file.
* Set up continuous integration (ci.inria.fr)...
Check that Menhir builds (and the test pass)
with multiple versions of OCaml.
* Add a command line option to control how "MenhirLib" should be named in the * Add a command line option to control how "MenhirLib" should be named in the
generated code. (Suggested by Gabriel Scherer.) generated code. (Suggested by Gabriel Scherer.)
