GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
POTTIER Francois
menhir
b113b1b6
b113b1b6
POTTIER Francois
Ground any unassigned sort variables at the end of sort inference.
At log level 3, display the inferred sort of every symbol.
7cd31e1d
2
src/SortInference.ml
b113b1b6
@@ -8,9 +8,6 @@ open SortUnification
(* Error handling. *)
let
print
v
variable
string
print
decode
v
(* In [check_arity], in principle, [arity1] is the expected arity and [arity2]
is the actual arity. This distinction does not make much sense, though, as
we do not know which is wrong, the declaration site or the use site. So, we
@@ -45,12 +42,14 @@ let unify sym sort1 sort2 =
unify
sort1
sort2
Unify
v1
v2
let
print
v
print
decode
v
in
error
position
sym
"how is the symbol
%s
parameterized?
\n
It is used at sorts %s and %s.
\n
The sort %s is not compatible with the sort %s."
value
sym
print
sort1
print
sort2
print
v1
print
v2
Occurs
v1
v2
let
print
v
print
decode
v
in
error
position
sym
"how is the symbol
%s
parameterized?
\n
\n
@@ -203,7 +202,7 @@ let check_grammar env g =
let
infer_grammar
g
grammar
sort
Env
t
let
infer_grammar
g
grammar
ground_
sort
Env
t
(* For each (terminal or nonterminal) symbol, allocate a unification
variable. The terminal symbols have sort [star], so we can use
@@ -233,9 +232,23 @@ let infer_grammar (g : grammar) : sort Env.t =
check_grammar
env
g
(* TEMPORARY ground any unassigned sort variables? *)
(* Decode the environment, so our user doesn't have to deal with
unification variables. *)
Env
map
decode
env
let
env
Env
map
decode
env
in
(* Ground any unassigned sort variables. (These should occur only in
unreachable parts of the grammar.) This guarantees that the user
does not have to deal with sort variables. *)
let
env
Env
map
ground
env
in
(* At log level 3, display the inferred sort of every symbol. *)
Error
logG
3
fun
f
Env
iter
fun
x
gsort
Printf
fprintf
f
"%s :: %s
\n
x
print
unground
gsort
env
env
src/SortInference.mli
b113b1b6
@@ -3,6 +3,6 @@ open SortUnification
(* [infer_grammar g] performs sort inference for the grammar [g],
rejecting the grammar if it is ill-sorted. It returns a map of
(terminal and nonterminal) symbols to sorts. *)
ground
sorts. *)
val
infer_grammar
grammar
sort
StringMap
t
val
infer_grammar
grammar
ground_
sort
StringMap
t
