Commit b0f2ef19 authored by POTTIER Francois's avatar POTTIER Francois
TODO note.
parent f3825381
* Place INCREMENTAL_ENGINE in a separate file, so as to reduce confusion
and allow including this file in the documentation
* Add an incremental version of the calc demo * Add an incremental version of the calc demo
* Test incremental interface in conjunction with %parameter * Test incremental interface in conjunction with %parameter
* Include comments in the generated .mli file (Interface) * Include comments in the generated .mli file (Interface)?
* Document the incremental interface * Document the incremental interface
* Confirm and understand why the code back-end slows down by 50% * Confirm and understand why the code back-end slows down by 50%
between 4.01.0 and 4.02.1. Use the tag last309 for this purpose. between 4.01.0 and 4.02.1. Use the tag last309 for this purpose,
or the master branch.
* Update the source code for 4.02 * Update the source code for 4.02
change String to Bytes where appropriate change String to Bytes where appropriate
