GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
POTTIER Francois
menhir
aea80b11
aea80b11
POTTIER Francois
New functions [transition_tokens] and [reduction_tokens] in Lr0.
5580435d
2
src/lr0.ml
aea80b11
@@ -371,6 +371,16 @@ let transition
in
k
Array
map
interpret
state
sr
(* [transition_tokens transitions] returns the set of tokens (terminal symbols)
that are labels of outgoing transitions in the table [transitions]. *)
let
transition_tokens
transitions
SymbolMap
fold
fun
symbol
_target
toks
match
symbol
Symbol
T
tok
TerminalSet
add
tok
toks
Symbol
N
_
toks
transitions
TerminalSet
empty
(* Equality of states. *)
let
equal
k1
toksr1
as
state1
k2
toksr2
as
state2
@@ -636,6 +646,14 @@ let reductions_table state =
add_reductions
prod
toks
reductions
TerminalMap
empty
reductions
state
(* [reduction_tokens reductions] returns the domain of the reductions table
[table], in the form of a set of tokens. *)
let
reduction_tokens
reductions
TerminalMap
fold
fun
tok
_prods
toks
TerminalSet
add
tok
toks
reductions
TerminalSet
empty
(* This inverts a mapping of tokens to productions into a mapping of
productions to sets of tokens. *)
src/lr0.mli
aea80b11
@@ -85,6 +85,11 @@ val start: node -> lr1state
val
transitions
lr1state
lr1state
SymbolMap
t
val
transition
Symbol
t
lr1state
lr1state
val
transition_tokens
target
SymbolMap
t
TerminalSet
t
(* Information about the reductions at a state. *)
(* See also [reductions_table] further on. *)
@@ -169,6 +174,11 @@ val reductions_table: lr1state -> reductions
val
invert
reductions
TerminalSet
t
ProductionMap
t
val
reduction_tokens
reductions
TerminalSet
t
(* [has_eos_conflict transitions reductions] tells whether a state has
an end-of-stream conflict, that is, a reduction action on [#] and
at least one other (shift or reduce) action. *)
