GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
POTTIER Francois
menhir
a72952fe
a72952fe
POTTIER Francois
Manual: fix some pointers to the demos.
e1b85522
Pipeline
#116422
passed with stages
in 25 seconds
doc/manual.tex
a72952fe
@@ -1011,8 +1011,8 @@ The identity semantic action \dpfidentityaction is here synonymous with
\dpaction
\nt
x
Other illustrations of the new syntax can be found in
the directories
\distrib
demos/calc-new-syntax
-dune
\distrib
demos/calc-ast
-dune
the directories
\distrib
\distrib
demos/calc-ast
\section
Advanced features
@@ -4479,13 +4479,13 @@ into a single parser,
say
\verb
parser.{ml,mli}
create a file named
\verb
parser.mlypack
that contains the module names
\verb
A B
See the
\distrib
demos
directory
for examples.
See the
directory
\distrib
demos
/ocamlbuild
for examples.
To deal with
\messages
files (
\sref
sec:errors:new
use the rules provided in the file
\distrib
demos/ocamlbuild/myocamlbuild.ml
% Advanced scenario: to use --only-tokens and -external-tokens,
% use .mlypack + _tags + myocamlbuild.ml. Not explained here,
% but \distrib{demos/calc-two} contains an example.
ocamlbuild/
\question
How do I use
\menhir
\dune
Please use
\dune
version 1.4.0
or newer, as it has appropriate built-in rules for Menhir parsers. In the
@@ -4504,7 +4504,7 @@ instead, write \texttt{(infer true)} or \texttt{(infer false)}, as done above.
(The default is
\texttt
true
.) Ordinary command line switches, like
\oexplain
\odump
, are passed as part of the
\texttt
flags
line, as done above.
The directory
\distrib
demos/calc
-dune
The directory
\distrib
demos/calc
% (and others like it)
offers an example.
