Commit a2d27552 authored by POTTIER Francois's avatar POTTIER Francois
Long discussion of spurious reductions. The paper is now too long.
parent 324acba3
...@@ -20,6 +20,8 @@ ...@@ -20,6 +20,8 @@
then look for a blank line, higher up, between two sentences. then look for a blank line, higher up, between two sentences.
explain the meaning of the spurious reductions warning (sometimes missing!) explain the meaning of the spurious reductions warning (sometimes missing!)
--compile-errors could warn about messages wider than 80 columns --compile-errors could warn about messages wider than 80 columns
--on-error-reduce should warn about arguments which are not names of terminal symbols
and should remove any spaces in the names!
could also warn statically about out-of-range $i? could also warn statically about out-of-range $i?
document the workflow document the workflow
remove lr.csv when done remove lr.csv when done
Supports Markdown
