GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
POTTIER Francois
menhir
9f622c39
9f622c39
POTTIER Francois
Re-established an assertion. Comment.
08e069ff
src/LRijkstra.ml
9f622c39
@@ -34,6 +34,9 @@
@@ -34,6 +34,9 @@
Thus, in principle, we work with ``real'' terminal symbols only. However,
we encode [any] as [#] -- see below. *)
(* NOTE: THIS FILE IS COMPILED WITH -noassert BY DEFAULT. If you would like
the assertions to be tested at runtime, change that in the file _tags. *)
(* To delay the side effects performed by this module, we wrap everything in
@@ -568,7 +571,7 @@ end = struct
MySet
Make
struct
MySet
Make
struct
type
t
fact
type
t
fact
let
compare
fact1
fact2
let
compare
fact1
fact2
assert (fact1.lookahead = fact2.lookahead);
assert
fact1
lookahead
fact2
lookahead
let
c
Trie
compare
fact1
position
fact2
position
in
let
c
Trie
compare
fact1
position
fact2
position
in
if
c
then
c
else
if
c
then
c
else
let
z
fact1
lookahead
in
let
z
fact1
lookahead
in
