Commit 9980f815 authored by POTTIER Francois's avatar POTTIER Francois
A simplification in LinearizedArray.
parent 65c06565
(* The [entry] array contains offsets into the [data] array. It has [n+1]
elements if the original (unencoded) array has [n] elements. The value
of [entry.(n)] is the length of the [data] array. This convention is
natural and allows avoiding a special case. *)
type 'a t =
(* data: *) 'a array *
(* entry: *) int array
......@@ -6,11 +11,13 @@ let make (a : 'a array array) : 'a t =
let n = Array.length a in
(* Build the entry array. *)
let size = ref 0 in
let entry = Array.init n (fun i ->
let entry = Array.init (n + 1) (fun i ->
let s = !size in
if i < n then
size := s + Array.length a.(i);
s
) in
assert (entry.(n) = !size);
(* Build the data array. *)
let i = ref 0
and j = ref 0 in
......@@ -28,18 +35,8 @@ let make (a : 'a array array) : 'a t =
let length ((_, entry) : 'a t) : int =
Array.length entry
(* This auxiliary function conceptually extends the array [entry]
to the case where [i] is [n]. *)
let _entry (data, entry) i =
let n = Array.length entry in
assert (0 <= i && i <= n);
if i < n then
entry.(i)
else
Array.length data
let row_length ((_, entry) as la : 'a t) i : int =
_entry la (i + 1) - entry.(i)
let row_length ((_, entry) : 'a t) i : int =
entry.(i + 1) - entry.(i)
let read ((data, entry) as la : 'a t) i j : 'a =
assert (0 <= j && j < row_length la i);
......@@ -55,6 +52,6 @@ let rec read_interval data i j =
else
data.(i) :: read_interval data (i + 1) j
let read_row ((data, entry) as la : 'a t) i : 'a list =
read_interval data entry.(i) (_entry la (i + 1))
let read_row ((data, entry) : 'a t) i : 'a list =
read_interval data entry.(i) entry.(i + 1)
