GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
POTTIER Francois
menhir
87c4a6f2
87c4a6f2
POTTIER Francois
Removed a comment. Memoization of trivial calls do not seem effective.
1950faea
src/Coverage.ml
87c4a6f2
@@ -544,10 +544,6 @@ let () =
(* TEMPORARY implement and exploit [Lr1.ImperativeNodeMap] using an array *)
(* TEMPORARY the code in this module should run only if --coverage is set *)
(* TEMPORARY gain a constant factor by memoizing [nullable_first_prod]? *)
(* TEMPORARY gain some time and space by not memoizing "trivial" calls
e.g. when n = 0
e.g. when there is just one recursive call with i+1
(* TEMPORARY maybe cutoff didn't work because productions were not sorted by length? *)
(* TEMPORARY key idea? stop searching as soon as the lower bound predicted by [MINIMAL]
is reached *)
