Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 86639b79 authored by Frédéric Bour's avatar Frédéric Bour
proof-of-concept
parent d1026227
......@@ -19,9 +19,9 @@ let rec loop lexbuf (checkpoint : int I.checkpoint) =
and offer it to the parser, which will produce a new
checkpoint. Then, repeat. *)
let token = Lexer.token lexbuf in
let startp = lexbuf.lex_start_p
and endp = lexbuf.lex_curr_p in
let checkpoint = I.offer checkpoint (token, startp, endp) in
let startp = lexbuf.lex_start_pos
and endp = lexbuf.lex_curr_pos in
let checkpoint = I.offer checkpoint (token, (startp, endp)) in
loop lexbuf checkpoint
| I.Shifting _
| I.AboutToReduce _ ->
......@@ -57,7 +57,8 @@ let fail lexbuf (_ : int I.checkpoint) =
(lexeme_start lexbuf)
let loop lexbuf result =
let supplier = I.lexer_lexbuf_to_supplier Lexer.token lexbuf in
let get_location l = (l.Lexing.lex_start_pos, l.Lexing.lex_curr_pos) in
let supplier = I.lexer_lexbuf_to_supplier Lexer.token get_location lexbuf in
I.loop_handle succeed (fail lexbuf) supplier result
......@@ -66,8 +67,9 @@ let loop lexbuf result =
let process (line : string) =
let lexbuf = from_string line in
let loc = (lexbuf.lex_start_pos, lexbuf.lex_curr_pos) in
try
loop lexbuf (Parser.Incremental.main lexbuf.lex_curr_p)
loop lexbuf (Parser.Incremental.main loc)
| Lexer.Error msg ->
Printf.fprintf stderr "%s%!" msg
......@@ -89,7 +91,7 @@ let rec repeat channel =
process optional_line;
if continue then
repeat channel
let () =
repeat (from_channel stdin)
%location<MyLocation>
%token <int> INT
%token PLUS MINUS TIMES DIV
%token LPAREN RPAREN
......@@ -17,17 +19,17 @@ main:
expr:
| i = INT
{ i }
{ prerr_endline (MyLocation.trace $loc);i }
| LPAREN e = expr RPAREN
{ e }
{ prerr_endline (MyLocation.trace $loc);e }
| e1 = expr PLUS e2 = expr
{ e1 + e2 }
{ prerr_endline (MyLocation.trace $loc); e1 + e2 }
| e1 = expr MINUS e2 = expr
{ e1 - e2 }
{ prerr_endline (MyLocation.trace $loc);e1 - e2 }
| e1 = expr TIMES e2 = expr
{ e1 * e2 }
{ prerr_endline (MyLocation.trace $loc);e1 * e2 }
| e1 = expr DIV e2 = expr
{ e1 / e2 }
{ prerr_endline (MyLocation.trace $loc);e1 / e2 }
| MINUS e = expr %prec UMINUS
{ - e }
{ prerr_endline (MyLocation.trace $loc);- e }
......@@ -5,7 +5,7 @@ ifndef MENHIR
MENHIR := $(shell ../find-menhir.sh)
endif
MENHIRFLAGS := --infer
MENHIRFLAGS := --infer --table
OCAMLBUILD := ocamlbuild -use-ocamlfind -use-menhir -menhir "$(MENHIR) $(MENHIRFLAGS)"
......@@ -2,6 +2,7 @@
%token EOL
%left PLUS MINUS /* lowest precedence */
%left TIMES DIV /* medium precedence */
......@@ -406,3 +406,18 @@ module type ENGINE = sig
and type location := location
(* This signature describes the signature of locations manipulated by Menhir. *)
module type LOCATION = sig
type t
val empty_after : t -> t
val join : t array -> t
val trace : t -> string
val get : Lexing.lexbuf -> t
module As_location(M : LOCATION) : LOCATION with type t = M.t = M
......@@ -29,6 +29,7 @@ and interface_item =
| IIInclude of module_type
(* Submodule. *)
| IIModule of string * module_type
| IIModuleAlias of string * Stretch.t
(* Comment. *)
| IIComment of string
......@@ -239,6 +240,7 @@ and modexpr =
| MVar of string
| MStruct of structure
| MApp of modexpr * modexpr
| MTextual of Stretch.t
(* Structures. *)
......@@ -75,8 +75,14 @@ let tposition =
(* A location is a pair of positions. This might change in the future. *)
let tlocation =
tpair tposition tposition
let default_tlocation = tpair tposition tposition
let tlocation ~public grammar =
match grammar.UnparameterizedSyntax.location with
| None -> default_tlocation
| Some _path ->
let path = if public then "Location.t" else "Menhir__Location.t" in
TypApp (path, [])
(* The type of lexer buffers. *)
......@@ -252,6 +258,7 @@ let interface_item_to_structure_item = function
| IIValDecls _
| IIInclude _
| IIModule (_, _)
| IIModuleAlias (_, _)
| IIComment _ ->
......@@ -35,7 +35,8 @@ val tint: typ
val tstring: typ
val texn: typ
val tposition: typ
val tlocation: typ
val default_tlocation: typ
val tlocation: public:bool -> UnparameterizedSyntax.grammar -> typ
val tlexbuf: typ
val tobj : typ
......@@ -72,6 +72,9 @@ let startp =
let endp =
"_endpos"
let loc =
"_loc"
(* Types for semantic values. *)
......@@ -53,6 +53,7 @@ val token: string
val beforeendp: string
val startp: string
val endp: string
val loc: string
......@@ -1581,6 +1581,12 @@ module OnErrorReduce = struct
(* [%location] declaration. *)
let location_module = G.grammar.location
end (* module Make *)
......@@ -588,6 +588,11 @@ module OnErrorReduce : sig
val location_module : Stretch.t option
(* Diagnostics. *)
......@@ -112,7 +112,7 @@ let actiondef grammar symbol branch =
PAnnot (PVar endp, tposition) ::
PAnnot (PVar starto, tint) ::
PAnnot (PVar endo, tint) ::
PAnnot (PVar loc, tlocation) ::
PAnnot (PVar loc, tlocation ~public:false grammar) ::
formals
) [] branch.producers
in
......@@ -130,8 +130,8 @@ let actiondef grammar symbol branch =
PAnnot (PVar "_endofs", tint) ::
PAnnot (PVar "_endofs__0_", tint) ::
PAnnot (PVar "_symbolstartofs", tint) ::
PAnnot (PVar "_sloc", tlocation) ::
PAnnot (PVar "_loc", tlocation) ::
PAnnot (PVar "_sloc", tlocation ~public:false grammar) ::
PAnnot (PVar "_loc", tlocation ~public:false grammar) ::
formals
in
......@@ -151,6 +151,13 @@ let actiondef grammar symbol branch =
| _ ->
EFun (formals, body)
let location_module grammar =
| None -> []
| Some path ->
let md = MApp (MVar "MenhirLib.EngineTypes.As_location", MTextual path) in
[SIModuleDef ("Menhir__Location", md)]
(* [program] turns an entire grammar into a test program. *)
let program grammar =
......@@ -209,6 +216,7 @@ let program grammar =
[ SIFunctor (grammar.parameters,
interface_to_structure (tokentypedef grammar) @
location_module grammar @
SIStretch grammar.preludes ::
SIValDefs (false, [ begindef; def; enddef ]) ::
SIStretch grammar.postludes ::
......@@ -311,6 +311,8 @@ and inline_modexpr = function
MStruct (inline_structure s)
| MApp (e1, e2) ->
MApp (inline_modexpr e1, inline_modexpr e2)
| MTextual stretch ->
MTextual stretch
(* The external entry point. *)
......@@ -15,6 +15,11 @@ open UnparameterizedSyntax
open IL
open CodeBits
(* The type of locations. *)
(* The [Error] exception. *)
......@@ -64,7 +69,7 @@ let incremental =
let entrytypescheme_incremental grammar symbol =
let t = TypTextual (ocamltype_of_start_symbol grammar symbol) in
type2scheme (marrow [ tlocation ] (checkpoint t))
type2scheme (marrow [ tlocation ~public:true grammar ] (checkpoint t))
......@@ -128,7 +133,7 @@ let inspection_api grammar () =
(* The incremental API. *)
let incremental_engine () : module_type =
let incremental_engine grammar : module_type =
with_types WKNonDestructive
"MenhirLib.IncrementalEngine.INCREMENTAL_ENGINE"
......@@ -136,8 +141,7 @@ let incremental_engine () : module_type =
"token", (* NOT [tctoken], which is qualified if [--external-tokens] is used *)
TokenType.ttoken;
"location",
CodeBits.tlocation
"location", tlocation ~public:true grammar
let incremental_entry_points grammar : interface =
......@@ -159,7 +163,7 @@ let incremental_api grammar () : interface =
interpreter,
MTSigEnd (
IIComment "The incremental API." ::
IIInclude (incremental_engine()) ::
IIInclude (incremental_engine grammar) ::
listiflazy Settings.inspection (inspection_api grammar)
......@@ -170,11 +174,19 @@ let incremental_api grammar () : interface =
| None -> []
| Some mpath -> [IIModuleAlias ("Location", mpath)]
(* The complete interface of the generated parser. *)
let interface grammar = [
IIFunctor (grammar.parameters,
monolithic_api grammar @
listiflazy Settings.table (incremental_api grammar)
......@@ -676,19 +676,32 @@ let () =
(* [$startpos] and [$endpos] have been expanded away. *)
assert false
| Position (_, _, FlavorLocation) ->
(* [$loc] and [$sloc] have been expanded away. *)
assert false
begin match Grammar.location_module with
| None ->
assert false
| Some _ ->
(* $loc has been kept for custom locations. *)
| Position (RightNamed _, WhereSymbolStart, _) ->
(* [$symbolstartpos(x)] does not exist. *)
assert false
| Position (RightNamed id, where, _) ->
(* If the semantic action mentions [$startpos($i)], then the
[i]-th symbol in the right-hand side must keep track of
its start position. Similarly for end positions. *)
Array.iteri (fun i id' ->
if id = id' then
record_ConVar true (rhs.(i), where)
) ids
| None ->
if id = id' then
) ids
| Some _ ->
(* $startpos when using custom locations should have been
rejected before. *)
) (Action.keywords action)
); (* end of loop on productions *)
......@@ -696,6 +696,8 @@ and modexpr f = function
structend f s
| MApp (e1, e2) ->
fprintf f "%a (%a)" modexpr e1 modexpr e2
| MTextual mpath ->
fprintf f "(%a)" (stretch true) mpath
let valdecl f (x, ts) =
fprintf f "val %s: %a" x typ ts.body
......@@ -743,6 +745,8 @@ and interface_item f item =
fprintf f "include %a" module_type mt
| IIModule (name, mt) ->
fprintf f "module %s : %a" name module_type mt
| IIModuleAlias (name, mpath) ->
fprintf f "module %s = %a" name (stretch true) mpath
| IIComment comment ->
fprintf f "(* %s *)" comment
end;
......@@ -159,10 +159,14 @@ let reducecellparams prod i _symbol (next : pattern) : pattern =
let ids = Production.identifiers prod in
let loc =
PTuple [
PVar (Printf.sprintf "_startpos_%s_" ids.(i));
PVar (Printf.sprintf "_endpos_%s_" ids.(i));
| None ->
PTuple [
| Some _ ->
PVar (Printf.sprintf "_loc_%s_" ids.(i))
in
PRecord [
......@@ -199,8 +203,11 @@ let reducecellcasts prod i symbol casts =
(* 2015/11/04. The start and end positions of an epsilon production are obtained
by taking the end position stored in the top stack cell (whatever it is). *)
let location_of_top_stack_cell =
ERecordAccess(EVar stack, flocation)
let endpos_of_top_stack_cell =
EApp (EVar "Pervasives.snd", [ERecordAccess(EVar stack, flocation)])
EApp (EVar "Pervasives.snd", [location_of_top_stack_cell])
(* This is the body of the [reduce] function associated with
production [prod]. It assumes that the variables [env] and [stack]
......@@ -236,21 +243,36 @@ let reducebody prod =
by the OCaml compiler. *)
let posbindings =
( PVar beforeendp,
( PVar startp,
if length > 0 then
EVar (Printf.sprintf "_startpos_%s_" ids.(0))
else
| None ->
[ PVar beforeendp,
( PVar endp,
if length > 0 then
EVar (Printf.sprintf "_endpos_%s_" ids.(length - 1))
else
EVar startp
; PVar startp,
if length > 0 then
else
; PVar endp,
if length > 0 then
else
EVar startp
| Some _ ->
[ PVar loc,
if length > 0 then
let loc id = EVar (Printf.sprintf "_loc_%s_" id) in
let locs = EArray (Array.to_list (Array.map loc ids)) in
EApp (
EVar "Menhir__Location.join",
[locs]
else
EApp (
EVar "Menhir__Location.empty_after",
in
(* This cannot be one of the start productions. *)
......@@ -264,25 +286,26 @@ let reducebody prod =
let act =
EAnnot (Action.to_il_expr action, type2scheme (semvtypent nt))
in
let positions =
[EVar startp; EVar endp]
let elocation =
| None -> ETuple [EVar startp; EVar endp]
| Some _ -> EVar loc
in
EComment (
Production.print prod,
blet (
(pat, EVar stack) :: (* destructure the stack *)
casts @ (* perform type casts *)
posbindings @ (* bind [startp] and [endp] *)
[ PVar semv, act ], (* run the user's code and bind [semv] *)
(* Return a new stack, onto which we have pushed a new stack cell. *)
ERecord [ (* the new stack cell *)
fstate, EVar state; (* the current state after popping; it will be updated by [goto] *)
fsemv, ERepr (EVar semv); (* the newly computed semantic value *)
flocation, ETuple positions; (* the newly computed start and end positions *)
fnext, EVar stack; (* this is the stack after popping *)
flocation, elocation; (* the newly computed start and end positions *)
......@@ -301,7 +324,9 @@ let semantic_action prod =
ELet (
[ PVar stack, ERecordAccess (EVar env, fstack) ] @
(if Production.length prod = 0 then [ PVar state, ERecordAccess (EVar env, fcurrent) ] else []),
else []),
reducebody prod
......@@ -661,18 +686,53 @@ let trace =
let location_typ = {
typename = "location";
typeparams = [];
typerhs = TAbbrev tlocation;
typeconstraint = None;
| None -> []
| Some path ->
MTextual path))]
let post_location_module =
| None -> []
| Some path ->
[SIModuleDef ("Location", MTextual path)]
let location_typ =
| None ->
{ typename = "location"
; typeparams = []
; typerhs = TAbbrev default_tlocation
; typeconstraint = None
| Some _ ->
; typeparams = []
; typerhs = TAbbrev (TypApp ("Menhir__Location.t", []))
let trace_location = {
valpublic = false;
valpat = PVar "trace_location";
valval = EVar "MenhirLib.General.trace_location";
| None ->
{ valpublic = false
; valpat = PVar "trace_location"
; valval = EVar "MenhirLib.General.trace_location"
| Some _ ->
{ valpublic = false
; valval = EVar "Menhir__Location.trace"
let get_location =
| None -> "MenhirLib.General.get_location"
| Some _ -> "Menhir__Location.get"
......@@ -722,7 +782,7 @@ let monolithic_entry_point state nt t =
EVar entry, [
EIntConst (Lr1.number state);
EVar lexer;
EVar "MenhirLib.General.get_location";
EVar get_location;
EVar lexbuf
......@@ -1022,6 +1082,8 @@ let program =
location_module @
(* Define the tables. *)
SIModuleDef (tables,
......@@ -1030,8 +1092,6 @@ let program =
exception [Error] and of the type [token]. *)
SIInclude (MVar basics);
SITypeDefs [location_typ];
(* This is a non-recursive definition, so none of the names
defined here are visible in the semantic actions. *)
SIValDefs (false, [
......@@ -1047,7 +1107,11 @@ let program =
goto;
semantic_action;
trace;
(* Define location_typ last, to satisfy the functor interface without
making the type location visible from the semantic actions. *)
......@@ -1121,6 +1185,8 @@ let program =
