GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
POTTIER Francois
menhir
822ce6f6
822ce6f6
POTTIER Francois
Re-ordering.
dbf87984
src/astar.mli
822ce6f6
@@ -18,14 +18,14 @@ module Make (G : sig
val
sources
node
unit
unit
(* Whether a node is a goal node. *)
val
is_goal
node
bool
(* [successors n f] presents each of [n]'s successors, in
an arbitrary order, to [f], together with the cost of
the edge that was followed. *)
val
successors
node
label
int
node
unit
unit
val
is_goal
node
bool
(* An estimate of the cost of the shortest path from the
supplied node to some goal node. This estimate must
be a correct under-approximation of the actual cost. *)
