Commit 81dcc7dd authored by POTTIER Francois's avatar POTTIER Francois
Merge remote-tracking branch 'origin/fix'
This modifies the analyses in [Grammar] to use [Fix] as the fixed point
computation algorithm.
parents 0f324090 7e608c59
(* The Boolean lattice. *)
type property =
bool
let bottom =
false
let equal (b1 : bool) (b2 : bool) =
b1 = b2
let is_maximal b =
b
include Fix.PROPERTY with type property = bool
(* The natural numbers, completed with [Infinity], and ordered towards
zero (i.e. [Infinity] is [bottom], [Finite 0] is [top]). *)
type t =
| Finite of int
| Infinity
type property =
t
let equal p1 p2 =
match p1, p2 with
| Finite i1, Finite i2 ->
i1 = i2
| Infinity, Infinity ->
true
| _, _ ->
false
let bottom =
Infinity
let is_maximal p =
match p with
| Finite 0 ->
true
| _ ->
false
let min p1 p2 =
match p1, p2 with
if i1 <= i2 then p1 else p2
| p, Infinity
| Infinity, p ->
p
let min_lazy p1 p2 =
match p1 with
| Finite 0 ->
p1
| _ ->
min p1 (Lazy.force p2)
let add p1 p2 =
match p1, p2 with
Finite (i1 + i2)
| _, _ ->
Infinity
let add_lazy p1 p2 =
match p1 with
| Infinity ->
Infinity
| _ ->
add p1 (Lazy.force p2)
let print p =
match p with
| Finite i ->
string_of_int i
| Infinity ->
"infinity"
type t =
| Finite of int
| Infinity
include Fix.PROPERTY with type property = t
val min: t -> t -> t
val add: t -> t -> t
val min_lazy: t -> t Lazy.t -> t
val add_lazy: t -> t Lazy.t -> t
val print: t -> string
(* This is an enriched version of [CompletedNat], where we compute not just
numbers, but also lists of matching length. During the fixed point
computation, instead of manipulating actual lists, we manipulate only
recipes for constructing lists. These recipes can be evaluated by the user
after the fixed point has been reached. *)
(* A property is either [Finite (n, xs)], where [n] is a natural number and
[xs] is a (recipe for constructing a) list of length [n]; or [Infinity]. *)
type 'a t =
| Finite of int * 'a list Lazy.t
| Infinity
let equal p1 p2 =
match p1, p2 with
| Finite (i1, _), Finite (i2, _) ->
i1 = i2
true
| _, _ ->
false
let bottom =
Infinity
let is_maximal p =
match p with
| Finite (0, _) ->
true
| _ ->
false
let min p1 p2 =
match p1, p2 with
| p, Infinity
| Infinity, p ->
p
match p1 with
| Finite (0, _) ->
p1
| _ ->
let add p1 p2 =
match p1, p2 with
| Finite (i1, xs1), Finite (i2, xs2) ->
Finite (
i1 + i2,
(* The only list operation in the code! *)
lazy (Lazy.force xs1 @ Lazy.force xs2)
| _, _ ->
Infinity
match p1 with
| Infinity ->
Infinity
| _ ->
let print conv p =
match p with
| Finite (i, xs) ->
string_of_int i ^ " " ^
String.concat " " (List.map conv (Lazy.force xs))
| Infinity ->
"infinity"
type 'a t =
| Infinity
val bottom: 'a t
val equal: 'a t -> 'b t -> bool
val is_maximal: 'a t -> bool
val min: 'a t -> 'a t -> 'a t
val add: 'a t -> 'a t -> 'a t
val min_lazy: 'a t -> 'a t Lazy.t -> 'a t
val add_lazy: 'a t -> 'a t Lazy.t -> 'a t
val print: ('a -> string) -> 'a t -> string
(* BEGIN PERSISTENT_MAPS *)
module type PERSISTENT_MAPS = sig
type key
type 'data t
val empty: 'data t
val add: key -> 'data -> 'data t -> 'data t
val find: key -> 'data t -> 'data
val iter: (key -> 'data -> unit) -> 'data t -> unit
(* END PERSISTENT_MAPS *)
(* BEGIN IMPERATIVE_MAPS *)
module type IMPERATIVE_MAPS = sig
type key
type 'data t
val create: unit -> 'data t
val clear: 'data t -> unit
val add: key -> 'data -> 'data t -> unit
(* END IMPERATIVE_MAPS *)
(* BEGIN IMPERATIVE_MAP *)
module type IMPERATIVE_MAP = sig
type key
type data
val set: key -> data -> unit
val get: key -> data option
(* END IMPERATIVE_MAP *)
module PersistentMapsToImperativeMaps
(M : PERSISTENT_MAPS)
: IMPERATIVE_MAPS with type key = M.key
and type 'data t = 'data M.t ref
= struct
type key =
M.key
type 'data t =
'data M.t ref
let create () =
ref M.empty
let clear t =
t := M.empty
let add k d t =
t := M.add k d !t
let find k t =
M.find k !t
let iter f t =
M.iter f !t
module ImperativeMapsToImperativeMap
(M : IMPERATIVE_MAPS)
(D : sig type data end)
: IMPERATIVE_MAP with type key = M.key
and type data = D.data
= struct
type key =
M.key
type data =
D.data
let m =
M.create()
let set k d =
M.add k d m
let get k =
try
Some (M.find k m)
with Not_found ->
None
module ConsecutiveIntegerKeysToImperativeMaps
(K : sig val n: int end)
: IMPERATIVE_MAPS with type key = int
and type 'data t = 'data option array
= struct
open K
type key =
int
type 'data t =
'data option array
let create () =
Array.make n None
let clear m =
Array.fill m 0 n None
let add key data m =
m.(key) <- Some data
let find key m =
match m.(key) with
| None ->
raise Not_found
| Some data ->
let iter f m =
Array.iteri (fun key data ->
match data with
| None ->
| Some data ->
f key data
) m
module HashTableAsImperativeMaps
(H : Hashtbl.HashedType)
: IMPERATIVE_MAPS with type key = H.t
= struct
include Hashtbl.Make(H)
let create () =
create 1023
let add key data table =
add table key data
let find table key =
find key table
module TrivialHashedType
(T : sig type t end)
: Hashtbl.HashedType with type t = T.t
= struct
include T
let equal =
let hash =
Hashtbl.hash
(* This module defines three signatures for association maps, together
with a number of conversion functors. *)
(* Following the convention of the ocaml standard library, the [find]
functions raise [Not_found] when the key is not a member of the
domain of the map. By contrast, [get] returns an option. *)
type key
type 'data t
val empty: 'data t
type key
type 'data t
type key
type data
(* An implementation of persistent maps can be made to satisfy the interface
of imperative maps. An imperative map is represented as a persistent map,
wrapped within a reference cell. *)
(* An implementation of imperative maps can be made to satisfy the interface
of a single imperative map. This map is obtained via a single call to [create]. *)
(* An implementation of imperative maps as arrays is possible if keys
are consecutive integers. *)
(* An implementation of imperative maps as a hash table. *)
(* A trivial implementation of equality and hashing. *)
......@@ -187,14 +187,14 @@ let rec follow1 tok derivation offset' = function
at the moment, so let's skip it. *)
derivation
| (item, _, offset) :: configs ->
let _, _, rhs, pos, length = Item.def item in
let prod, _, rhs, pos, length = Item.def item in
if offset = offset' then
(* This is an epsilon transition. Attack a new line and add
a comment that explains why the lookahead symbol is
produced or inherited. *)
let nullable, first = Analysis.nullable_first_rhs rhs (pos + 1) in
let nullable, first = Analysis.nullable_first_prod prod (pos + 1) in
if TerminalSet.mem tok first then
......@@ -304,7 +304,7 @@ let explain_reduce_item
if pos < length then
match rhs.(pos) with
| Symbol.N nt ->
let first : bool = TerminalSet.mem tok first in
let lookahead' =
if nullable then first || lookahead else first
This diff is collapsed.
......@@ -373,12 +373,12 @@ module Analysis : sig
val first: Nonterminal.t -> TerminalSet.t
(* [nullable_first_rhs rhs i] considers the string of symbols found at
offset [i] in the array [rhs]. It returns its NULLABLE flag as well
(* [nullable_first_prod prod i] considers the suffix of the the production
[prod] defined by offset [i]. It returns its NULLABLE flag as well
as its FIRST set. The offset [i] must be contained between [0] and
[n], where [n] is the length of [rhs], inclusive. *)
[n], inclusive, where [n] is the length of production [prod]. *)
val nullable_first_rhs: Symbol.t array -> int -> bool * TerminalSet.t
val nullable_first_prod: Production.index -> int -> bool * TerminalSet.t
(* [explain_first_rhs tok rhs i] explains why the token [tok] appears
in the FIRST set for the string of symbols found at offset [i] in
......@@ -170,7 +170,9 @@ open StateLattice
let stack_states : Lr1.node -> property =
let module F =
Fix.Make(Lr1.ImperativeNodeMap)(StateLattice)
Fix.Make
(Maps.PersistentMapsToImperativeMaps(Lr1.NodeMap))
(StateLattice)
in
F.lfp (fun node (get : Lr1.node -> property) ->
......@@ -171,7 +171,7 @@ module Closure (L : Lookahead.S) = struct
let constant, transmits =
L.constant first, nullable
else
(* No epsilon transitions leave this item. *)
......@@ -64,31 +64,6 @@ module NodeSet =
module NodeMap =
Map.Make (Node)
module ImperativeNodeMap = struct
type key =
NodeMap.key
type 'data t =
'data NodeMap.t ref
let create () =
ref NodeMap.empty
let clear t =
t := NodeMap.empty
let add k d t =
t := NodeMap.add k d !t
let find k t =
NodeMap.find k !t
let iter f t =
NodeMap.iter f !t
(* Output debugging information if [--follow-construction] is enabled. *)
......@@ -25,8 +25,6 @@ module NodeSet : Set.S with type elt = node
module NodeMap : Map.S with type key = node
module ImperativeNodeMap : Fix.IMPERATIVE_MAPS with type key = node
(* These are the automaton's entry states, indexed by the start productions. *)
val entry: node ProductionMap.t
