Commit 6b8fd353 authored by POTTIER Francois's avatar POTTIER Francois
GNUmakefile: fix.
parent e651fca2
...@@ -51,11 +51,10 @@ export CDPATH= ...@@ -51,11 +51,10 @@ export CDPATH=
# Distribution. # Distribution.
# The version number is automatically set to the current date, # The version number is automatically set to the current date,
# unless DATE is defined on the command line. # unless DATE is defined on the command line.
ifndef $(DATE)
DATE := $(shell /bin/date +%Y%m%d) DATE := $(shell /bin/date +%Y%m%d)
endif
PACKAGE := menhir-$(DATE) PACKAGE := menhir-$(DATE)
CURRENT := $(shell pwd) CURRENT := $(shell pwd)
...@@ -269,4 +268,3 @@ pin: ...@@ -269,4 +268,3 @@ pin:
unpin: unpin:
opam pin remove menhir opam pin remove menhir
