Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 6adfc5b7 authored by POTTIER Francois's avatar POTTIER Francois
Add $MENHIR_STDLIB.
parent 231025f9
2017/01/01:
Add $MENHIR_STDLIB as a way of controlling where Menhir looks for the file
standard.mly. This environment variable overrides the installation-time
default setting, and is itself overridden by the --stdlib command line
switch. (Requested by Jonathan Protzenko.)
2017/01/01:
Makefile fix: filter out '\r' in the output of menhir --suggest-ocamlfind,
so that the Makefile works when Menhir is compiled as a Windows executable.
......@@ -239,9 +239,8 @@ channel. When \nt{level} is 2, the \emph{nullable}, \emph{FIRST}, and
grammar specification to be ignored. This is especially useful in order
to understand whether these keywords help solve any conflicts.
\docswitch{\onostdlib} This switch causes the standard library \emph{not}
to be implicitly joined with the grammar specifications whose names are
explicitly provided on the command line.
\docswitch{\onostdlib} This switch instructs Menhir to \emph{not} use
its standard library (\sref{sec:library}).
\docswitch{\oocamlc \nt{command}} This switch controls how \ocamlc is
invoked (when \oinfer is used). It allows setting both the name of
......@@ -275,6 +274,11 @@ postprocessing.
An end user who uses \ocamlbuild does not need to mention this switch:
\ocamlbuild uses it automatically.
\docswitch{\ostdlib \nt{directory}} This switch controls the directory where
the standard library (\sref{sec:library}) is found. It takes precedence over
both the installation-time directory and the directory that may be specified
via the environment variable \verb+$MENHIR_STDLIB+.
\docswitch{\ostrict} This switch causes several warnings about the grammar
and about the automaton to be considered errors. This includes warnings about
useless precedence declarations, non-terminal symbols that produce the empty
......@@ -322,11 +326,6 @@ query menhirLib}.
value (i.e., either \texttt{true} or \texttt{false}), which indicates whether
\menhirlib was installed via \ocamlfind.
where the standard library is found. It allows overriding the default
directory that is set at installation time. The trailing \texttt{/} character
is optional.
\docswitch{\otable} This switch causes \menhir to use its table-based
back-end, as opposed to its (default) code-based back-end. When \otable is
used, \menhir produces significantly more compact and somewhat slower parsers.
......@@ -1137,6 +1136,18 @@ causes \nt{plist}(\nt{X}) to recognize a list of \nt{X}'s, where the empty
list is represented by the empty string, and a non-empty list is delimited
with parentheses and comma-separated.
The standard library is stored in a file named \texttt{standard.mly}, which is
installed at the same time as Menhir. By default, Menhir attempts to find this
file in the directory where this file was installed. This can be overridden by
setting the environment variable
\verb+$MENHIR_STDLIB+. If defined, this variable should contain the path of
the directory where \texttt{standard.mly} is stored. (This path may
end with a \texttt{/} character.) This can be overridden also via the
command line switch \ostdlib.
The command line switch \onostdlib instructs Menhir to \emph{not} load the
standard library.
\section{Conflicts}
......@@ -124,9 +124,20 @@ let filenames =
let no_stdlib =
ref false
(* By default, [stdlib_path] is [Installation.libdir], that is, the directory
that was specified when Menhir was compiled. This is overridden by the
environment variable $MENHIR_STDLIB, if it is defined, and by the --stdlib
command line option, if present. *)
let stdlib_path =
ref Installation.libdir
let () =
try
stdlib_path := Sys.getenv "MENHIR_STDLIB"
with Not_found ->
let insert name =
filenames := StringSet.add name !filenames
