GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
POTTIER Francois
menhir
6a0e6726
6a0e6726
POTTIER Francois
Comment.
59bffe97
src/codeBackend.ml
6a0e6726
@@ -686,9 +686,13 @@ let letunless e x e1 e2 =
(* Calling conventions. *)
(* The contents of a stack cell, exposed as individual parameters. The
choice of identifiers is suitable for use in the definition of
[run]. *)
(* The contents of a stack cell, exposed as individual parameters. The choice of
identifiers is suitable for use in the definition of [run]. *)
(* This code also determines the layout of a stack cell. The first field in a
stack cell is always a pointer to the rest of the stack; it is followed by
the fields listed below, each of which may or may not appear. [runpushcell]
and [gotopushcell] are the two places where stack cells are allocated. *)
let
runcellparams
var
holds_state
symbol
elementif
holds_state
var
state
Supports
