Commit 6800b5c8 authored by POTTIER Francois's avatar POTTIER Francois
Fix LICENSE to remove obsolete references to the QPL.
At the same time, remove the linking exception for the Generator.
Also, mention that the files in test/ are not covered by any license.
parent 24e4e1a2
......@@ -5,19 +5,14 @@ In the following, "THE LIBRARY" refers to the following files:
2- the OCaml source files whose basename appears in the file
src/menhirLib.mlpack and whose extension is ".ml" or ".mli".
"THE GENERATOR" refers to all other files in this archive.
THE LIBRARY is distributed under the terms of the GNU Library General
Public License version 2 (included below).
"THE GENERATOR" refers to all other files in this archive or repository,
except those in the subdirectory test/, which are not covered by this license.
THE GENERATOR is distributed under the terms of the GNU General Public
As a special exception to the Q Public Licence, you may develop
application programs, reusable components and other software items
that link with the original or modified versions of the Generator
and are not made available to the general public, without any of the
additional requirements listed in clause 6c of the Q Public licence.
As a special exception to the GNU Library General Public License, you
may link, statically or dynamically, a "work that uses the Library"
