GitLab
Support
Community forum
Keyboard shortcuts
menhir
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
POTTIER Francois
menhir
6636a4a7
6636a4a7
POTTIER Francois
Rename [Positions.lex_join] to [Positions.import]. Change its API. Use [$loc].
f7876493
5
5 changed files
11 additions
11 deletions
+11
-11
src/fancy-parser.mly
+1
-1
src/lexer.mll
src/lexer.mll
+1
-1
src/positions.ml
src/positions.ml
+5
-5
src/positions.mli
src/positions.mli
+1
-1
src/yacc-parser.mly
src/yacc-parser.mly
+3
-3
6636a4a7
@@ -271,7 +271,7 @@ production:
producers
producers
oprec
oprec
ParserAux
new_production_level
ParserAux
Positions
lex_join
startpos
endpos
Positions
import
loc
src/lexer.mll
6636a4a7
@@ -461,7 +461,7 @@ rule main = parse
let
openingpos
lexeme_start_p
lexbuf
in
let
openingpos
lexeme_start_p
lexbuf
in
let
stretchpos
lexeme_end_p
lexbuf
in
let
stretchpos
lexeme_end_p
lexbuf
in
let
closingpos
attribute
openingpos
lexbuf
in
let
closingpos
attribute
openingpos
lexbuf
in
let
pos
Positions
lex_join
openingpos
lexeme_end_p
lexbuf
in
let
pos
Positions
import
openingpos
lexeme_end_p
lexbuf
in
let
attr
mk_stretch
stretchpos
closingpos
false
in
let
attr
mk_stretch
stretchpos
closingpos
false
in
if
percent
then
if
percent
then
(* No [%] sign: this is a normal attribute. *)
src/positions.ml
6636a4a7
@@ -86,8 +86,8 @@ let join x1 x2 =
end_of_position
if
x2
dummy
then
x1
else
x2
end_of_position
if
x2
dummy
then
x1
else
x2
let
lex_join
x1
x2
let
import
x
x1
x2
x
let
join_located
l1
l2
f
let
join_located
l1
l2
f
@@ -138,13 +138,13 @@ type positions =
t
list
t
list
let
one
pos
position
positions
let
one
pos
position
positions
pos
pos
(* or: lex_join pos pos *)
import
pos
pos
let
two
pos1
position
pos2
position
positions
let
two
pos1
position
pos2
position
positions
lex_join
pos1
pos2
import
pos1
pos2
let
lexbuf
lexbuf
lexbuf
positions
let
lexbuf
lexbuf
lexbuf
positions
lex_join
lexbuf
lex_start_p
lexbuf
lex_curr_p
import
lexbuf
lex_start_p
lexbuf
lex_curr_p
let
print
pos
position
let
print
pos
position
Printf
printf
Printf
printf
src/positions.mli
6636a4a7
@@ -82,7 +82,7 @@ val filename_of_position: t -> string
starts and stops where [p2] stops. *)
val
join
t
t
t
val
join
t
t
t
val
lex_join
Lexing
position
Lexing
position
t
val
import
Lexing
position
Lexing
position
t
val
ljoinf
a
t
a
list
t
val
ljoinf
a
t
a
list
t
src/yacc-parser.mly
6636a4a7
@@ -346,7 +346,7 @@ production:
rev
rev
2
2
ParserAux
ParserAux
Positions
lex_join
symbol_start_pos
symbol_end_pos
Positions
import
symbol_start_pos
symbol_end_pos
producers
producers
@@ -361,8 +361,8 @@ producers:
producer
producer
actual
attributes
actual
attributes
Positions
lex_join
symbol_start_pos
symbol_end_pos
None
2
Positions
import
symbol_start_pos
symbol_end_pos
None
2
LID
EQUAL
actual
attributes
LID
EQUAL
actual
attributes
Positions
lex_join
symbol_start_pos
symbol_end_pos
Some
3
4
Positions
import
symbol_start_pos
symbol_end_pos
Some
3
4
