Commit 6563739a authored by POTTIER Francois's avatar POTTIER Francois
Merge branch 'master' of gitlab.inria.fr:fpottier/menhir
parents e518bc58 69511635
...@@ -27,6 +27,13 @@ ...@@ -27,6 +27,13 @@
- Change of LICENSE. Clarify the status of test/. - Change of LICENSE. Clarify the status of test/.
- Send CompCert pull request. - Send CompCert pull request.
* The table back-end should not use Invariant.prodstack,
and should produce code for all semantic actions, regardless
of whether they are ever reduced.
* The table back-end should not use Invariant at all?
And we should be able to save time by not running Invariant.
* Move more of ErrorReports from CompCert to MenhirLib. * Move more of ErrorReports from CompCert to MenhirLib.
In [show], might want to apply [shorten] to the output of [f]. In [show], might want to apply [shorten] to the output of [f].
...@@ -714,6 +714,12 @@ module Make (T : TABLE) = struct ...@@ -714,6 +714,12 @@ module Make (T : TABLE) = struct
current states via their numbers (this seems cleaner than using OCaml's current states via their numbers (this seems cleaner than using OCaml's
polymorphic equality). *) polymorphic equality). *)
(* The two fields that are not compared by [equal], namely [error] and
[triple], are overwritten by the function [discard], which handles
[InputNeeded] checkpoints. Thus, if [equal env1 env2] holds, then the
checkpoints [input_needed env1] and [input_needed env2] are
equivalent: they lead the parser to behave in the same way. *)
let equal env1 env2 = let equal env1 env2 =
env1.stack == env2.stack && env1.stack == env2.stack &&
number env1.current = number env2.current number env1.current = number env2.current
...@@ -290,11 +290,13 @@ module type INCREMENTAL_ENGINE = sig ...@@ -290,11 +290,13 @@ module type INCREMENTAL_ENGINE = sig
val current_state_number: 'a env -> int val current_state_number: 'a env -> int
(* [equal env1 env2] tells whether the parser configurations [env1] and (* [equal env1 env2] tells whether the parser configurations [env1] and
[env2] are equal in the sense that the automaton's current state is [env2] are equal in the sense that the automaton's current state is the
the same in [env1] and [env2] and the stack is *physically* the same same in [env1] and [env2] and the stack is *physically* the same in
in [env1] and [env2]. If [equal env1 env2] is [true], then the list [env1] and [env2]. If [equal env1 env2] is [true], then the list of stack
of stack elements, as observed via [pop] and [top], must be the same elements, as observed via [pop] and [top], must be the same in [env1] and
in [env1] and [env2]. The function [equal] has time complexity O(1). *) [env2]. Also, if [equal env1 env2], then the checkpoints [input_needed
env1] and [input_needed env2] are equivalent. The function [equal] has
val equal: 'a env -> 'a env -> bool val equal: 'a env -> 'a env -> bool
...@@ -143,7 +143,7 @@ let define_and_measure (x, e) = ...@@ -143,7 +143,7 @@ let define_and_measure (x, e) =
(* Code generation for semantic actions. *) (* Code generation for semantic actions. *)
(* The functions [reducecellparams] and [reducebody] are adpated from (* The functions [reducecellparams] and [reducebody] are adapted from
[CodeBackend]. *) [CodeBackend]. *)
(* Things are slightly more regular here than in the code-based (* Things are slightly more regular here than in the code-based
