Commit 5bfbf871 authored by POTTIER Francois's avatar POTTIER Francois
Documentation: move a sentence about the type [production].
parent 53c67a0d
...@@ -2187,6 +2187,9 @@ eventually be produced if the parser succeeds. ...@@ -2187,6 +2187,9 @@ eventually be produced if the parser succeeds.
\end{verbatim} \end{verbatim}
The abstract type \verb+production+ represents a production of the grammar. The abstract type \verb+production+ represents a production of the grammar.
The ``start productions'' (which do not exist in an \mly file, but are
constructed by Menhir internally) are \emph{not} part of this type.
%% type 'a checkpoint %% type 'a checkpoint
...@@ -2487,10 +2490,6 @@ The function \verb+production_index+ converts a production to an integer ...@@ -2487,10 +2490,6 @@ The function \verb+production_index+ converts a production to an integer
number, whereas the function \verb+find_production+ carries out the reverse number, whereas the function \verb+find_production+ carries out the reverse
conversion. It is an error to apply \verb+find_production+ to an invalid conversion. It is an error to apply \verb+find_production+ to an invalid
index. index.
constructed by Menhir internally) are \emph{not} part of the set of
productions represented by the type \verb+production+.
%% type element %% type element
