Nous avons procédé ce jeudi matin 08 avril 2021 à une MAJ de sécurité urgente. Nous sommes passé de la version 13.9.3 à la version 13.9.5 les releases notes correspondantes sont ici:
https://about.gitlab.com/releases/2021/03/17/security-release-gitlab-13-9-4-released/
https://about.gitlab.com/releases/2021/03/31/security-release-gitlab-13-10-1-released/
Commit 54be00ca authored by POTTIER Francois's avatar POTTIER Francois
Updated comment.
parent d4aae8b6
......@@ -26,23 +26,21 @@ module Make (T : TABLE) = struct
(* OK, OK. I said I would stop using [Obj.magic], yet here we go again.
I need to extend the type [T.token] with an extra element, which
represents the [error] pseudo-token. I don't want to pay an extra
box in memory or an extra field in the [env] record. I don't want
to add a branch to the type [T.token] because that would bother the
user (that would be an incompatible change) and that would make some
exhaustive case analyses appear non-exhaustive. So, here we go. We
allocate a dummy box in memory and use its address as a unique value
which cannot possibly be confused with a legit inhabitant of the type
[token]. (Right?) *)
(* OK, OK. I said I would stop using [Obj.magic], yet here we go again. I
need to extend the type [T.token] with an extra element, which represents
the [error] pseudo-token. I don't want to pay an extra box in memory or
an extra field in the [env] record. (I have measured the cost of moving
from 5 to 6 fields in this record to be 30%. This is more than I
expected!) I don't want to add a branch to the type [T.token] because
that would bother the user (that would be an incompatible change) and
that would make some exhaustive case analyses appear non-exhaustive. So,
here we go. We allocate a dummy box in memory and use its address as a
unique value which cannot possibly be confused with a legit inhabitant of
the type [token]. (Right?) *)
let error_token : token =
Obj.magic (ref 0xDEADBEEF)
(* We adopt the convention that we have an [error] token on the input
stream if and only if [env.token] is [deadbeef]. *)
(* In the code-based back-end, the [run] function is sometimes responsible
