Commit 53d6057e authored by POTTIER Francois's avatar POTTIER Francois
Bibliography update. No months.
Added links to CompCert's github repository.
parent ceed3a3a
This diff is collapsed.
@Misc{compcert-github,
author = "Xavier Leroy",
title = "The {CompCert C} verified compiler",
year = "2014",
howpublished = "\url{https://github.com/AbsInt/CompCert}",
...@@ -4,6 +4,7 @@ ...@@ -4,6 +4,7 @@
\usepackage{amstext} \usepackage{amstext}
\usepackage[T1]{fontenc} \usepackage[T1]{fontenc}
\usepackage[latin1]{inputenc} \usepackage[latin1]{inputenc}
\usepackage{moreverb}
\usepackage{tikz} \usepackage{tikz}
\usepackage{xspace} \usepackage{xspace}
\usepackage{mymacros} \usepackage{mymacros}
...@@ -2071,8 +2072,9 @@ named \verb+unambiguous+. ...@@ -2071,8 +2072,9 @@ named \verb+unambiguous+.
% correspond bien à la fin du Stream. % correspond bien à la fin du Stream.
The parsers produced by \menhir's Coq back-end must be linked with a Coq The parsers produced by \menhir's Coq back-end must be linked with a Coq
library, which can be found in the CompCert tree~\cite{compcert}, in the library, which can be found in the CompCert tree~\cite{compcert,compcert-github}, in the
\verb+cparser/validator+ subdirectory. Additionally, CompCert can be used as \href{https://github.com/AbsInt/CompCert/tree/master/cparser/validator}
{\texttt{cparser/validator}} subdirectory. Additionally, CompCert can be used as
an example if one wishes to use \menhir to generate a formally verified parser an example if one wishes to use \menhir to generate a formally verified parser
as part of some other project. as part of some other project.
...@@ -2089,6 +2091,7 @@ Extract Constant Int31.compare31 => "Camlcoq.Int31.compare". ...@@ -2089,6 +2091,7 @@ Extract Constant Int31.compare31 => "Camlcoq.Int31.compare".
Extract Constant Int31.On => "0". Extract Constant Int31.On => "0".
Extract Constant Int31.In => "1". Extract Constant Int31.In => "1".
\end{comment} \end{comment}
% Peut-être en faire aussi un fichier de librairie?
...@@ -2291,7 +2294,7 @@ Coq proofs that come with it. ...@@ -2291,7 +2294,7 @@ Coq proofs that come with it.
% Bibliography. % Bibliography.
\bibliographystyle{plain} \bibliographystyle{plain}
\bibliography{english} \bibliography{english,local}
\end{document} \end{document}
