Commit 53c67a0d authored by POTTIER Francois's avatar POTTIER Francois
Document [state_has_default_reduction].
parent 5a3903d4
...@@ -2527,16 +2527,20 @@ a pair of twice the initial position that was passed as an argument ...@@ -2527,16 +2527,20 @@ a pair of twice the initial position that was passed as an argument
to \verb+main+. to \verb+main+.
%% val has_default_reduction %% val has_default_reduction
%% val state_has_default_reduction
\begin{verbatim} \begin{verbatim}
val env_has_default_reduction: 'a env -> bool val env_has_default_reduction: 'a env -> bool
val state_has_default_reduction: _ lr1state -> bool
\end{verbatim} \end{verbatim}
The function \verb+env_has_default_reduction+ When applied to an environment \verb+env+ taken from a checkpoint of the form
tells whether the parser is about to perform a default reduction. \verb+AboutToReduce (env, prod)+, the function
In particular, when applied to an environment \verb+env+ taken from a result of \verb+env_has_default_reduction+ tells whether the reduction that is about to
the form \verb+AboutToReduce (env, prod)+, it tells whether the reduction take place is a default reduction.
that is about to take place is a default reduction.
\verb+state_has_default_reduction s+ tells whether the state \verb+s+ has a default
reduction. This includes the case where \verb+s+ is an accepting state.
