Commit 48f613df authored by POTTIER Francois's avatar POTTIER Francois
Fix an incorrect comment.
parent 074c6643
......@@ -86,8 +86,7 @@ module type INCREMENTAL_ENGINE = sig
(* [loop supplier checkpoint] begins parsing from [checkpoint], reading
tokens from [supplier]. It continues parsing until it reaches a
checkpoint of the form [Accepted v] or [Rejected]. In the former case, it
returns [v]. In the latter case, it raises [Error]. This is how the
monolithic API is implemented on top of the incremental API. *)
returns [v]. In the latter case, it raises the exception [Error]. *)
val loop: supplier -> 'a checkpoint -> 'a
......@@ -95,13 +94,13 @@ module type INCREMENTAL_ENGINE = sig
[checkpoint], reading tokens from [supplier]. It continues parsing until
it reaches a checkpoint of the form [Accepted v] or [HandlingError env]
(or [Rejected], but that should not happen, as [HandlingError _] will be
observed first). In the former case, it returns [v]. In the latter case,
it calls [fail] with this checkpoint. It cannot raise [Error].
observed first). In the former case, it calls [succeed v]. In the latter
case, it calls [fail] with this checkpoint. It cannot raise [Error].
This means that Menhir's traditional error-handling procedure (which pops
the stack until a state that can act on the [error] token is found) does
not get a chance to run. Instead, the user can implement her own error
handling code, in the [fail] function. *)
handling code, in the [fail] continuation. *)
val loop_handle:
('a -> 'answer) ->
