Commit 4364e009 authored by POTTIER Francois's avatar POTTIER Francois
English.
parent f3a89210
2016/05/4: 2016/05/04:
In the Coq backend, we split the largest definitions into smaller In the Coq backend, split the largest definitions into smaller
ones. This circumvenient a limitation of vm_compute in 32 bits ones. This circumvenents a limitation of vm_compute on 32 bit
machines. This also makes us able to do some sharing between the machines. This also enables us to perform sharing between
definitions, so that the generated files are much smaller. definitions, so that the generated files are much smaller.
2016/03/11: 2016/03/11:
...@@ -440,4 +440,3 @@ Fixed behavior of --depend option. ...@@ -440,4 +440,3 @@ Fixed behavior of --depend option.
2006/01/06: 2006/01/06:
Removed reversed lists from the standard library. Removed reversed lists from the standard library.
Supports Markdown
