GitLab
Support
Community forum
Keyboard shortcuts
menhir
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
POTTIER Francois
menhir
40334621
POTTIER Francois
Cleanup. Comments.
5a9d6760
6
6 changed files
54 additions
39 deletions
+54
-39
TODO
TODO
+0
-2
demos/calc-incremental/calc.ml
+1
-1
src/IncrementalEngine.ml
+1
-1
src/tableBackend.ml
src/tableBackend.ml
+10
-9
src/tableFormat.ml
src/tableFormat.ml
+14
-5
src/tableInterpreter.ml
+28
-21
TODO
40334621
* Split TableFormat and TableInterpreter?
Add LinearizedArray to MenhirLib if needed.
* Possibly re-implement the function [symbol] using a packed
int array (going through [terminal] or [nonterminal] later).
Re-implement [production_defs], etc.
* Generate default printers for terminal and nonterminal.
Define printers for productions and items, parameterized
40334621
@@ -33,7 +33,7 @@ let print_element e : string =
match
e
match
e
I
Element
s
v
_
_
I
Element
s
v
_
_
let
open
Parser
Inspection
in
let
open
Parser
Inspection
in
match
symbol
s
match
incoming_
symbol
s
T
T_TIMES
T
T_TIMES
T
T_RPAREN
T
T_RPAREN
40334621
@@ -102,7 +102,7 @@ module type INSPECTION = sig
type
xsymbol
type
xsymbol
val
symbol
a
lr1state
a
symbol
val
incoming_
symbol
a
lr1state
a
symbol
val
lhs
production
xsymbol
val
lhs
production
xsymbol
src/tableBackend.ml
40334621
@@ -828,17 +828,17 @@ let nonterminal () =
(* Produce a function [symbol] that maps a state of type ['a lr1state]
incoming_
(represented as an integer value) to a value of type ['a symbol]. *)
(* The type [MenhirInterpreter.lr1state] is known (to us) to be an alias for
[int], so we can pattern match on it. To the user, though, it will be an
abstract type. *)
abstract type. *)
let
incoming_symbol
_def
let
incoming_symbol
assert
Settings
inspection
assert
Settings
inspection
define
define
"symbol"
incoming_
symbol"
EAnnot
EAnnot
EFun
PVar
state
EFun
PVar
state
EMatch
EVar
state
EMatch
EVar
state
@@ -1020,18 +1020,19 @@ let program =
SIInclude
MVar
more
SIInclude
MVar
more
SIInclude
MApp
MVar
make_inspection
MStruct
SIInclude
MApp
MVar
make_inspection
MStruct
SIInclude
MVar
more
(* This module must satisfy [INSPECTION_TABLES]. *)
(* [lr1state] *)
interface_to_structure
lr1state_redef
lr1state_redef
SIInclude
MVar
tables
(* only for [lhs] *)
(* [symbol], [xsymbol]. *)
SIInclude
MVar
more
(* [lhs] *)
SIInclude
MVar
tables
SIValDefs
false
SIValDefs
false
terminal
terminal
nonterminal
nonterminal
incoming_symbol
SIValDefs
false
incoming_symbol_def
rhs
rhs
lr0_core
lr0_core
lr0_items
lr0_items
src/tableFormat.ml
40334621
@@ -119,22 +119,31 @@ end
addition to the above) when [--inspection] is enabled. It is used as an
argument to [TableInterpreter.Inspection]. *)
(* TEMPORARY comment/document *)
module
type
INSPECTION_TABLES
sig
module
type
INSPECTION_TABLES
sig
(* These types are used in the types of the functions that follow.
In the generated [.ml] file, ['a lr1state] will be implemented
e.g. as [int], whereas the types ['a symbol] and [xsymbol] are
(generated) algebraic data types. *)
type
a
lr1state
type
a
lr1state
type
a
symbol
type
a
symbol
type
xsymbol
type
xsymbol
val
lhs
PackedIntArray
t
(* or: could include TABLES *)
(* Some of the tables that follow use encodings of (terminal and
nonterminal) symbols as integers. So, we need functions that
map the integer encoding of a symbol to its algebraic encoding. *)
val
terminal
int
xsymbol
val
terminal
int
xsymbol
val
nonterminal
int
xsymbol
val
nonterminal
int
xsymbol
(* A mapping of every (non-initial) state to its incoming symbol. *)
val
symbol
a
lr1state
a
symbol
val
incoming_symbol
a
lr1state
a
symbol
(* A left-hand side of every production. (Same as in [TABLES].) *)
val
lhs
PackedIntArray
t
(* The right-hand side of every production. This a linearized array
of arrays of integers, whose [data] and [entry] components have
40334621
@@ -171,28 +171,42 @@ end)
module
MakeInspection
T
TableFormat
INSPECTION_TABLES
struct
module
MakeInspection
T
TableFormat
INSPECTION_TABLES
struct
let
symbol
(* This auxiliary function decodes a packed linearized array, as created by
T
symbol
[TableBackend.linearize_and_marshal1]. Here, we read a row all at once. *)
let
read_packed_linearized
entry
PackedIntArray
t
PackedIntArray
t
i
int
int
list
LinearizedArray
read_row_via
PackedIntArray
get
PackedIntArray
get
entry
i
(* The function [incoming_symbol] is generated by the table back-end.
We just expose it. *)
let
incoming_symbol
T
incoming_symbol
(* The function [lhs] reads the table [lhs] and uses [T.nonterminal]
to decode the symbol. *)
let
lhs
prod
let
lhs
prod
let
nt
int
PackedIntArray
get
T
lhs
prod
in
T
nonterminal
PackedIntArray
get
T
lhs
prod
T
nonterminal
nt
(* The function [rhs] reads the table [rhs] and uses [decode_symbol]
to decode the symbol. The encoding was done by [encode_symbol] in
the table back-end. *)
let
decode_symbol
symbol
let
decode_symbol
symbol
let
kind
symbol
land
in
let
kind
symbol
land
in
if
kind
then
T
terminal
else
T
nonterminal
symbol
lsr
if
kind
then
T
terminal
else
T
nonterminal
symbol
lsr
let
rhs
prod
let
rhs
prod
let
entry
T
rhs
in
map
decode_symbol
T
rhs
prod
let
rhs
int
list
LinearizedArray
read_row_via
PackedIntArray
get
PackedIntArray
get
entry
prod
in
map
decode_symbol
rhs
(* This is a copy of [Item.export]. *)
(* The function [items] maps the LR(1) state [s] to its LR(0) core,
then uses [core] as an index into the table [lr0_items]. The
items are then decoded by the function [export] below, which is
essentially a copy of [Item.export]. *)
let
export
t
let
export
t
t
lsr
7
t
mod
128
t
lsr
7
t
mod
128
@@ -201,13 +215,6 @@ module MakeInspection (T : TableFormat.INSPECTION_TABLES) = struct
(* Map [s] to its LR(0) core. *)
let
core
PackedIntArray
get
T
lr0_core
s
in
let
core
PackedIntArray
get
T
lr0_core
s
in
(* Now use [core] to look up the [lr0_items] table. *)
let
entry
T
lr0_items
in
map
export
T
lr0_items
core
let
items
int
list
LinearizedArray
read_row_via
PackedIntArray
get
PackedIntArray
get
entry
core
in
map
export
items
