Commit 36de77c3 authored by POTTIER Francois's avatar POTTIER Francois
New module [Anonymous] to explicitly eliminate anonymous rules.
parent fe74a277
2016/05/18:
Anonymous rules now work also when used inside a parameterized rule.
(This did not work until now.)
2016/05/04: 2016/05/04:
In the Coq backend, split the largest definitions into smaller In the Coq backend, split the largest definitions into smaller
ones. This circumvenents a limitation of vm_compute on 32 bit ones. This circumvenents a limitation of vm_compute on 32 bit
...@@ -115,9 +115,6 @@ ...@@ -115,9 +115,6 @@
* Produce well-chosen (predictable) names for anonymous rules? * Produce well-chosen (predictable) names for anonymous rules?
* The construction of an anonymous rule should work also when the
body has parameters (should produce a parameterized rule).
* In the standard library, possibly rename "anonymous" and "embedded" and * In the standard library, possibly rename "anonymous" and "embedded" and
document them. The non-inline version allows embedding an action in the document them. The non-inline version allows embedding an action in the
middle of a rule. middle of a rule.
Warning: you are using the standard library and/or the %inline keyword. We
recommend switching on --infer in order to avoid obscure type error messages.
/* Test of the new anonymous rule syntax, including
anonymous rules nested in anonymous rules. */
%token<int> A B C D EOF
%start<int list> phrase
%inline id(X):
x = X { x }
foo:
A B { 1 }
bar:
C D { 2 }
phrase:
y = id(id(x = foo { x } | z = bar { z }))
t = id(x = foo { x } | id(z = bar { z }) { 2 })
EOF
{ y + t }
%start phrase
%token <int> EOF
%token <int> D
%token <int> C
%token <int> B
%token <int> A
%type <int list> phrase
foo:
_1 = A _2 = B
{ ( 1 )}
bar:
_1 = C _2 = D
{ ( 2 )}
phrase:
x000 = foo x00 = foo _3 = EOF
{let t =
let x0 = x00 in
let x =
let x = x0 in
( x )
in
( x )
in
let y =
let x00 = x000 in
let x =
let x0 = x00 in
let x =
let x = x0 in
( x )
in
( x )
in
( x )
in
( y + t )}
| x000 = foo z0000 = bar _3 = EOF
{let t =
let z000 = z0000 in
let x =
let z00 = z000 in
let _1 =
let z0 = z00 in
let x =
let z = z0 in
( z )
in
( x )
in
( 2 )
in
( x )
in
let y =
let x00 = x000 in
let x =
let x0 = x00 in
let x =
let x = x0 in
( x )
in
( x )
in
( x )
in
( y + t )}
| z000 = bar x00 = foo _3 = EOF
{let t =
let x0 = x00 in
let x =
let x = x0 in
( x )
in
( x )
in
let y =
let z00 = z000 in
let x =
let z0 = z00 in
let x =
let z = z0 in
( z )
in
( x )
in
( x )
in
( y + t )}
| z000 = bar z0000 = bar _3 = EOF
{let t =
let z000 = z0000 in
let x =
let z00 = z000 in
let _1 =
let z0 = z00 in
let x =
let z = z0 in
( z )
in
( x )
in
( 2 )
in
( x )
in
let y =
let z00 = z000 in
let x =
let z0 = z00 in
let x =
let z = z0 in
( z )
in
( x )
in
( x )
in
( y + t )}
open Syntax
(* For each anonymous rule, we define a fresh nonterminal symbol, and
replace the anonymous rule with a reference to this symbol. If the
anonymous rule appears inside a parameterized rule, then we must
define a parameterized nonterminal symbol. *)
(* This functor makes it easy to share mutable internal state between
the functions that follow. *)
module Run (X : sig end) = struct
(* A fresh name generator. *)
let fresh : unit -> string =
let next = ref 0 in
fun () ->
Printf.sprintf "__anonymous_%d" (Misc.postincrement next)
(* A rule accumulator. Used to collect the fresh definitions that we
produce. *)
let rules =
ref []
(* [anonymous pos parameters branches] deals with an anonymous rule,
at position [pos], which appears inside a possibly-parameterized
rule whose parameters are [parameters], and whose body is
[branches]. We assume that [branches] does not itself contain any
anonymous rules. As a side effect, we create a fresh definition,
and return its name. *)
let var (symbol : symbol) : parameter =
ParameterVar (Positions.with_pos Positions.dummy symbol)
let anonymous pos (parameters : symbol list) (branches : parameterized_branch list) : parameter =
(* Generate a fresh non-terminal symbol. *)
let symbol = fresh() in
(* Construct its definition. Note that it is implicitly marked %inline. *)
let rule = {
pr_public_flag = false;
pr_inline_flag = true;
pr_nt = symbol;
pr_positions = [ pos ]; (* this list is not allowed to be empty *)
pr_parameters = parameters;
pr_branches = branches
} in
(* Record this definition. *)
rules := rule :: !rules;
(* Return the symbol that stands for it. *)
Parameters.app (Positions.with_pos pos symbol) (List.map var parameters)
(* TEMPORARY should use as few parameters as possible *)
(* Traversal code. *)
let rec transform_parameter (parameters : symbol list) (p : parameter) : parameter =
match p with
| ParameterVar _ ->
p
| ParameterApp (x, ps) ->
ParameterApp (x, List.map (transform_parameter parameters) ps)
| ParameterAnonymous branches ->
let pos = Positions.position branches
and branches = Positions.value branches in
(* Do not forget the recursive invocation! *)
let branches = List.map (transform_parameterized_branch parameters) branches in
(* This is where the real work is done. *)
and transform_producer parameters (x, p) =
x, transform_parameter parameters p
and transform_parameterized_branch parameters branch =
let pr_producers =
List.map (transform_producer parameters) branch.pr_producers
in
{ branch with pr_producers }
let transform_parameterized_rule rule =
let pr_branches =
List.map (transform_parameterized_branch rule.pr_parameters) rule.pr_branches
in
{ rule with pr_branches }
(* The main entry point invokes the functor and reads its result. *)
let transform_partial_grammar g =
let module R = Run(struct end) in
let pg_rules = List.map R.transform_parameterized_rule g.pg_rules in
let pg_rules = !R.rules @ pg_rules in
{ g with pg_rules }
open Syntax
val transform_partial_grammar: partial_grammar -> partial_grammar
...@@ -56,7 +56,7 @@ grammar: ...@@ -56,7 +56,7 @@ grammar:
pg_filename = ""; (* filled in by the caller *) pg_filename = ""; (* filled in by the caller *)
pg_declarations = List.flatten ds; pg_declarations = List.flatten ds;
pg_rules = rs @ ParserAux.rules(); pg_rules = rs;
pg_trailer = t pg_trailer = t
...@@ -309,9 +309,13 @@ lax_actual: ...@@ -309,9 +309,13 @@ lax_actual:
(* 3- *) (* 3- *)
| /* leading bar disallowed */ | /* leading bar disallowed */
branches = branches branches = branches
{ let position = position (with_poss $startpos $endpos ()) in { ParameterAnonymous (with_poss $startpos $endpos branches) }
let symbol = ParserAux.anonymous position branches in (* 2016/05/18: we used to eliminate anonymous rules on the fly during
ParameterVar (with_pos position symbol) } parsing. However, when an anonymous rule appears in a parameterized
definition, the fresh nonterminal symbol that is created should be
parameterized. This was not done, and is not easy to do on the fly,
as it requires inherited attributes (or a way of simulating them).
We now use explicit abstract syntax for anonymous rules. *)
/* Formal or actual parameter lists are delimited with parentheses and /* Formal or actual parameter lists are delimited with parentheses and
...@@ -39,6 +39,13 @@ let () = ...@@ -39,6 +39,13 @@ let () =
(* Eliminate anonymous rules. *)
let partial_grammars =
List.map Anonymous.transform_partial_grammar partial_grammars
(* If several grammar files were specified, merge them. *) (* If several grammar files were specified, merge them. *)
let parameterized_grammar = let parameterized_grammar =
...@@ -71,42 +71,6 @@ let override pos o1 o2 = ...@@ -71,42 +71,6 @@ let override pos o1 o2 =
| _, None -> | _, None ->
o1 o1
(* Support for on-the-fly expansion of anonymous rules. Whenever such
a rule is encountered, we create a fresh non-terminal symbol, add
a definition of this symbol to a global variable, and return a
reference to this symbol. Quick and dirty. So, in the end, clean. *)
let next = ref 0 in
fun () ->
let rules =
ref []
let anonymous pos branches =
let rule = {
pr_nt = symbol;
pr_parameters = [];
} in
symbol
let rules () =
let result = !rules in
(* Reset the global state, in case we need to read several .mly files. *)
rules := [];
result
(* Only unnamed producers can be referred to using positional identifiers. (* Only unnamed producers can be referred to using positional identifiers.
Besides, such positions must be taken in the interval [1 Besides, such positions must be taken in the interval [1
.. List.length producers]. The output array [p] is such that .. List.length producers]. The output array [p] is such that
...@@ -116,4 +80,3 @@ let producer_names producers = ...@@ -116,4 +80,3 @@ let producer_names producers =
producers producers
|> List.map (fun (_, oid, _) -> Option.map Positions.value oid) |> List.map (fun (_, oid, _) -> Option.map Positions.value oid)
|> Array.of_list |> Array.of_list
...@@ -46,15 +46,6 @@ val normalize_producers: ...@@ -46,15 +46,6 @@ val normalize_producers:
val override: Positions.t -> 'a option -> 'a option -> 'a option val override: Positions.t -> 'a option -> 'a option -> 'a option
(* Support for on-the-fly expansion of anonymous rules. When such a
rule is encountered, invoke [anonymous], which creates a fresh
non-terminal symbol, records the definition of this symbol to a
global variable, and returns this symbol. In the end, invoke
[rules], so as to obtain a list of all recorded definitions. *)
val anonymous: Positions.t -> parameterized_branch list -> string
val rules: unit -> parameterized_rule list
(* [producer_names producers] returns an array [names] such that (* [producer_names producers] returns an array [names] such that
[names.(idx) = None] if the (idx + 1)-th producer is unnamed [names.(idx) = None] if the (idx + 1)-th producer is unnamed
and [names.(idx) = Some id] if it is called [id]. *) and [names.(idx) = Some id] if it is called [id]. *)
