Commit 33d9f284 authored by POTTIER Francois's avatar POTTIER Francois
Bump TIMEOUT to 2 hours. Remove --lalr.
parent b1eb7b73
...@@ -106,7 +106,7 @@ clean:: ...@@ -106,7 +106,7 @@ clean::
# Testing LRijkstra, that is, menhir --list-errors. # Testing LRijkstra, that is, menhir --list-errors.
ifeq ($(shell hostname),teraram) ifeq ($(shell hostname),teraram)
TIMEOUT := 3600 TIMEOUT := 7200
PARALLEL := -j40 PARALLEL := -j40
else else
TIMEOUT := 2 TIMEOUT := 2
...@@ -117,7 +117,7 @@ SINGLE = $(shell ls *.mly | egrep -v '.*-([1-9]).mly') ...@@ -117,7 +117,7 @@ SINGLE = $(shell ls *.mly | egrep -v '.*-([1-9]).mly')
%.log: %.mly %.log: %.mly
@ echo "Now dealing with: $<" | tee -a $@ @ echo "Now dealing with: $<" | tee -a $@
@ if (timeout $(TIMEOUT) $(MENHIR) --list-errors -la 2 --lalr $<) >>$@ 2>&1 ; then \ @ if (timeout $(TIMEOUT) $(MENHIR) --list-errors -la 2 $<) >>$@ 2>&1 ; then \
echo "$<: success." | tee -a $@ ; \ echo "$<: success." | tee -a $@ ; \
else \ else \
echo "$<: TIMEOUT (or failure)." | tee -a $@ ; \ echo "$<: TIMEOUT (or failure)." | tee -a $@ ; \
