Commit 32b78a19 authored by POTTIER Francois's avatar POTTIER Francois
TODO note.
parent 76caed2f
...@@ -5,6 +5,9 @@ ...@@ -5,6 +5,9 @@
* Update the demos to use ocamlbuild; remove Makefile.shared; * Update the demos to use ocamlbuild; remove Makefile.shared;
remove ocamldep.wrapper? remove OMakefiles remove ocamldep.wrapper? remove OMakefiles
* Voir si ça coûte cher de stocker la taille de la pile dans
chaque cellule
* Changes that could be applied to the code back-end: * Changes that could be applied to the code back-end:
[action] could now be inlined into [run] [action] could now be inlined into [run]
[initiate] and [bookkeeping] could be merged? [initiate] and [bookkeeping] could be merged?
