Commit 324acba3 authored by POTTIER Francois's avatar POTTIER Francois
Warn if an --on-error-reduce option is useless.
parent 1e34d32c
...@@ -1078,9 +1078,19 @@ let default_conflict_resolution () = ...@@ -1078,9 +1078,19 @@ let default_conflict_resolution () =
(* This code can run before we decide on the default reductions; this does (* This code can run before we decide on the default reductions; this does
not affect which default reductions will be permitted. *) not affect which default reductions will be permitted. *)
(* A count of how many states receive extra reductions through this mechanism. *)
let extra = let extra =
ref 0 ref 0
(* The set of nonterminal symbols in the left-hand side of an extra reduction. *)
let extra_nts =
ref StringSet.empty
let lhs prod : string =
Nonterminal.print false (Production.nt prod)
let extra_reductions () = let extra_reductions () =
iter (fun node -> iter (fun node ->
(* Just like a default reduction, an extra reduction should be forbidden (* Just like a default reduction, an extra reduction should be forbidden
...@@ -1091,30 +1101,41 @@ let extra_reductions () = ...@@ -1091,30 +1101,41 @@ let extra_reductions () =
let productions = invert (reductions node) in let productions = invert (reductions node) in
(* Keep only those whose left-hand symbol is marked [--on-error-reduce]. *) (* Keep only those whose left-hand symbol is marked [--on-error-reduce]. *)
let productions = ProductionMap.filter (fun prod _ -> let productions = ProductionMap.filter (fun prod _ ->
Settings.on_error_reduce (Nonterminal.print false (Production.nt prod)) StringSet.mem (lhs prod) Settings.on_error_reduce
) productions in ) productions in
(* Check if this only one such production remains. *) (* Check if this only one such production remains. *)
match ProductionMap.is_singleton productions with match ProductionMap.is_singleton productions with
| None -> | None ->
| Some (prod, _) -> | Some (prod, _) ->
(* An extra reduction is possible. Replace every error action with
a reduction of [prod]. *)
let acceptable = acceptable_tokens node in let acceptable = acceptable_tokens node in
let statistics = lazy (incr extra) in (* An extra reduction is possible. Replace every error action with
a reduction of [prod]. If we replace at least one error action
with a reduction, update [extra] and [extra_nts]. *)
let triggered = lazy (
incr extra;
extra_nts := StringSet.add (lhs prod) !extra_nts
) in
Terminal.iter_real (fun tok -> Terminal.iter_real (fun tok ->
if not (TerminalSet.mem tok acceptable) then begin if not (TerminalSet.mem tok acceptable) then begin
node.reductions <- TerminalMap.add tok [ prod ] node.reductions; node.reductions <- TerminalMap.add tok [ prod ] node.reductions;
Lazy.force statistics Lazy.force triggered
end end
end end
(* Info message. *)
if !extra > 0 then if !extra > 0 then
Error.logA 1 (fun f -> Error.logA 1 (fun f ->
Printf.fprintf f "Extra reductions on error were added in %d states.\n" !extra Printf.fprintf f "Extra reductions on error were added in %d states.\n" !extra
(* Warning about useless --on-error-reduce switches. *)
StringSet.iter (fun nt ->
if not (StringSet.mem nt !extra_nts) then
Error.grammar_warning []
(Printf.sprintf "the command line option --on-error-reduce %s is never useful." nt)
(* Define [fold_entry], which in some cases facilitates the use of [entry]. *) (* Define [fold_entry], which in some cases facilitates the use of [entry]. *)
...@@ -197,11 +197,11 @@ let echo_errors = ...@@ -197,11 +197,11 @@ let echo_errors =
let set_echo_errors filename = let set_echo_errors filename =
echo_errors := Some filename echo_errors := Some filename
let on_error_reduce_symbols = let on_error_reduce =
ref StringSet.empty ref StringSet.empty
let on_error_reduce_symbol nt = let on_error_reduce_symbol nt =
on_error_reduce_symbols := StringSet.add nt !on_error_reduce_symbols on_error_reduce := StringSet.add nt !on_error_reduce
let options = Arg.align [ let options = Arg.align [
"--base", Arg.Set_string base, "<basename> Specifies a base name for the output file(s)"; "--base", Arg.Set_string base, "<basename> Specifies a base name for the output file(s)";
...@@ -475,6 +475,6 @@ let update_errors = ...@@ -475,6 +475,6 @@ let update_errors =
let echo_errors = let echo_errors =
!echo_errors !echo_errors
let on_error_reduce nt = let on_error_reduce =
StringSet.mem nt !on_error_reduce_symbols !on_error_reduce
...@@ -208,9 +208,9 @@ val update_errors: string option ...@@ -208,9 +208,9 @@ val update_errors: string option
val echo_errors: string option val echo_errors: string option
(* This function takes a non-terminal symbol and tells whether it appears (* This is the set of non-terminal symbols that appear in a command line
in a command line switch of the form [--on-error-reduce]. This switch switch of the form [--on-error-reduce]. This switch indicates that extra
indicates that extra reductions are desired when an error is detected. *) reductions are desired when an error is detected. *)
val on_error_reduce: string -> bool val on_error_reduce: StringSet.t
