GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
POTTIER Francois
menhir
2e2f666e
2e2f666e
POTTIER Francois
Amélioration de test.sh pour s'arrêter si quelque chose ne compile pas.
3464ef4e
quicktest/test.sh
2e2f666e
@@ -12,7 +12,7 @@
@@ -12,7 +12,7 @@
# Build the parser with the code back-end and run it.
echo
"Building and running (code)..."
echo
make
-C
$CALC
MENHIR
$MENHIR
--trace"
clean
/dev/null
make
-C
$CALC
MENHIR
$MENHIR
--trace"
clean
/dev/null
make
-C
$CALC
MENHIR
$MENHIR
--trace"
/dev/null
make
-C
$CALC
MENHIR
$MENHIR
--trace"
/dev/null
exit
for
f
in
$DATA
.real.in
do
for
f
in
$DATA
.real.in
do
b
f
%.in
b
f
%.in
$CALC
/calc <
$f
$b
.code.out 2>
$b
.code.err
$CALC
/calc <
$f
$b
.code.out 2>
$b
.code.err
@@ -21,7 +21,7 @@ done
# Build the parser with the table back-end and run it.
echo
"Building and running (table)..."
echo
make
-C
$CALC
MENHIR
$MENHIR
--trace --table"
clean
/dev/null
make
-C
$CALC
MENHIR
$MENHIR
--trace --table"
clean
/dev/null
make
-C
$CALC
MENHIR
$MENHIR
--trace --table"
/dev/null
make
-C
$CALC
MENHIR
$MENHIR
--trace --table"
/dev/null
exit
for
f
in
$DATA
.real.in
do
for
f
in
$DATA
.real.in
do
b
f
%.in
b
f
%.in
$CALC
/calc <
$f
$b
.table.out 2>
$b
.table.err
$CALC
/calc <
$f
$b
.table.out 2>
$b
.table.err
@@ -30,7 +30,7 @@ done
# Build the parser with the table back-end (with --inspection) and run it.
echo
"Building and running (inspection)..."
echo
make
-C
$CALC
MENHIR
$MENHIR
--trace --table --inspection"
clean
/dev/null
make
-C
$CALC
MENHIR
$MENHIR
clean
/dev/null
make
-C
$CALC
MENHIR
$MENHIR
/dev/null
make
-C
$CALC
MENHIR
$MENHIR
/dev/null
exit
for
f
in
$DATA
.real.in
do
for
f
in
$DATA
.real.in
do
b
f
%.in
b
f
%.in
$CALC
/calc <
$f
$b
.inspection.out 2>
$b
.inspection.err
$CALC
/calc <
$f
$b
.inspection.out 2>
$b
.inspection.err
