Commit 2e2f666e authored by POTTIER Francois's avatar POTTIER Francois
Amélioration de test.sh pour s'arrêter si quelque chose ne compile pas.
parent 3464ef4e
...@@ -12,7 +12,7 @@ ...@@ -12,7 +12,7 @@
# Build the parser with the code back-end and run it. # Build the parser with the code back-end and run it.
echo "Building and running (code)..." echo "Building and running (code)..."
make -C $CALC MENHIR="$MENHIR --trace" clean >/dev/null make -C $CALC MENHIR="$MENHIR --trace" clean >/dev/null
make -C $CALC MENHIR="$MENHIR --trace" >/dev/null make -C $CALC MENHIR="$MENHIR --trace" >/dev/null || exit 1
for f in $DATA/*.real.in ; do for f in $DATA/*.real.in ; do
b=${f%.in} b=${f%.in}
$CALC/calc < $f > $b.code.out 2> $b.code.err $CALC/calc < $f > $b.code.out 2> $b.code.err
...@@ -21,7 +21,7 @@ done ...@@ -21,7 +21,7 @@ done
# Build the parser with the table back-end and run it. # Build the parser with the table back-end and run it.
echo "Building and running (table)..." echo "Building and running (table)..."
make -C $CALC MENHIR="$MENHIR --trace --table" clean >/dev/null make -C $CALC MENHIR="$MENHIR --trace --table" clean >/dev/null
make -C $CALC MENHIR="$MENHIR --trace --table" >/dev/null make -C $CALC MENHIR="$MENHIR --trace --table" >/dev/null || exit 1
$CALC/calc < $f > $b.table.out 2> $b.table.err $CALC/calc < $f > $b.table.out 2> $b.table.err
...@@ -30,7 +30,7 @@ done ...@@ -30,7 +30,7 @@ done
# Build the parser with the table back-end (with --inspection) and run it. # Build the parser with the table back-end (with --inspection) and run it.
echo "Building and running (inspection)..." echo "Building and running (inspection)..."
make -C $CALC MENHIR="$MENHIR --trace --table --inspection" clean >/dev/null make -C $CALC MENHIR="$MENHIR --trace --table --inspection" clean >/dev/null
make -C $CALC MENHIR="$MENHIR --trace --table --inspection" >/dev/null make -C $CALC MENHIR="$MENHIR --trace --table --inspection" >/dev/null || exit 1
$CALC/calc < $f > $b.inspection.out 2> $b.inspection.err $CALC/calc < $f > $b.inspection.out 2> $b.inspection.err
