Commit 2abafcc4 authored by POTTIER Francois's avatar POTTIER Francois
Modified compare.sh to begin with the current version, so we get
immediate feedback if it does not compile. Also fixed it to
properly show the compilation error message.
parent 323177d5
...@@ -20,31 +20,27 @@ then ...@@ -20,31 +20,27 @@ then
exit 1 exit 1
fi fi
# Go back to the last committed version. # Try the current version.
echo "Compiling (current uncommitted version)..."
make &> compile.new || { cat compile.new && exit 1 ; }
sleep 1
for FILE in "$@"
do
echo "Running ($FILE.mly)..."
{ time $MENHIR $BASE $OPT $BENCH/$FILE.mly ; } &>$FILE.new
done
# Try the last committed version.
git stash git stash
echo "Compiling (last committed version)..." echo "Compiling (last committed version)..."
( make &> compile.old || { cat compile.old && exit 1 ; }
make &> compile.old || exit 1 sleep 1
sleep 1 for FILE in "$@"
for FILE in "$@" do
do echo "Running ($FILE.mly)..."
echo "Running ($FILE.mly)..." { time $MENHIR $BASE $OPT $BENCH/$FILE.mly ; } &>$FILE.old
{ time $MENHIR $BASE $OPT $BENCH/$FILE.mly ; } &>$FILE.old done
done
# Come back to the current (uncommitted) version.
git stash pop git stash pop
make &> compile.new || exit 1
sleep 1
for FILE in "$@"
do
done
# Diff. # Diff.
for FILE in "$@" for FILE in "$@"
Supports Markdown
